  New Posts New Posts RSS Feed - new guy,new toys
new guy,new toys
hwscowboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hwscowboy Quote  Post ReplyReply Direct Link To This Post Topic: new guy,new toys
    Posted: 25-January-2010 at 2:57PM
Hi All
Well i'm the new guy here and i picked up a couple new toys yesterday.I went to loook at a 1968 torino and as i was looking at that one the guy says oh theres another one over there.My father had one as a kid so i always have had a desire to find another.Anyways i had only intended one getting the one but he made an offer i couldn't pass up so ended up with both.The second is also a 1968 but is a fairlane 500 by the badging.I have done a little research and from what i can tell both were made in the same plant,onne in june the other in dec.Both are the same color,metallice aqua,both have the same interior,aqua as well.One is a 302 car and one is a 289 car both c4 trannys.I will give the vins maybe someone can give me some more info on them.
car 1  8k65f******,body 63b,color f,trim 5k,date 27m,dso b6,axle/trans 2w.
car 2 8k35c*****,body 63b,color f,axle/trans 2w,dso b7,date 28f,trim 5k
I picked up both cars for under 1000.00 cdn for the pair,not sure if i'll make one out of t or build both,one is definitely rougher than the other but mostly intact.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 26-January-2010 at 1:12AM
following the links from the home page took me to here for your VIN and body code info...
good luck and welcome!
Carl
3 Formalroofs (2x72, 1x73), 72 GTS
90 T-Bird SC, 3.8l SUPERCHARGED
97 Dakota 2WD,Ext cab, 5.2L
Thats just my stuff!
You should see the wife's "HER STUFF" list!
