new guy,new toys |
Post Reply
| Author | |
hwscowboy
Joined: 24-January-2010 Location: calgary,alberta Status: Offline Points: 1 |
Quote Reply
Topic: new guy,new toysPosted: 25-January-2010 at 2:57PM |
Hi All
Well i'm the new guy here and i picked up a couple new toys yesterday.I went to loook at a 1968 torino and as i was looking at that one the guy says oh theres another one over there.My father had one as a kid so i always have had a desire to find another.Anyways i had only intended one getting the one but he made an offer i couldn't pass up so ended up with both.The second is also a 1968 but is a fairlane 500 by the badging.I have done a little research and from what i can tell both were made in the same plant,onne in june the other in dec.Both are the same color,metallice aqua,both have the same interior,aqua as well.One is a 302 car and one is a 289 car both c4 trannys.I will give the vins maybe someone can give me some more info on them.
car 1 8k65f******,body 63b,color f,trim 5k,date 27m,dso b6,axle/trans 2w.
car 2 8k35c*****,body 63b,color f,axle/trans 2w,dso b7,date 28f,trim 5k
I picked up both cars for under 1000.00 cdn for the pair,not sure if i'll make one out of t or build both,one is definitely rougher than the other but mostly intact.
Regul8r
Moderator Joined: 27-December-2007 Location: Ft Riley, KS Status: Offline Points: 2982 |
Quote Reply
Posted: 26-January-2010 at 1:12AM |
following the links from the home page took me to here for your VIN and body code info...
good luck and welcome!
Carl
3 Formalroofs (2x72, 1x73), 72 GTS 90 T-Bird SC, 3.8l SUPERCHARGED 97 Dakota 2WD,Ext cab, 5.2L 97 Suzuki Intruder 1400 Thats just my stuff! You should see the wife's "HER STUFF" list! |
Post Reply
Tweet
