  New Posts New Posts RSS Feed - New Track Boss Rotating assemblies
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Topic: New Track Boss Rotating assemblies
    Posted: 30-July-2016 at 2:22AM
http://351c.net/board/index.php?/topic/4338-new-track-boss-rotating-assemblies/
This is what I have been waiting to share with you guys. This way of centering the rod is important.
Product Release 5-20-2016
TMeyer is proud to announce the addition of rotating assemblies to its Track Boss product line and has committed to having Molnar Technologies produce the crankshaft and connecting rods for these assemblies. The Track Boss rotating assembly is setting a new standard with its “Centralign Design.”
All competitor assemblies that use the small block Chevy connecting rods have a problem aligning to the center of the piston. The Track Boss rotating assembly with the Centralign Design is engineered to correct this misalignment. True center alignment means better ring sealing and less twisting of the piston.
A Chevy rod will connect the piston to the crankshaft and produce power, however, you may leave power on the table due to the loss of ring seal. Late Model dirt racers have reported up to 30HP gains by using connecting rods with proper alignment.
Bottom Line: Get maximum power from your engine with the correct parts!
Get the Track Boss rotating assembly that has the Centralign Design.
And, when you consider all the parts included in the kits, the price is tough to beat!
Rotating Assembly #1 now available...
351M/400 stroker kit (444 kit) replacing the 434 kit
4.350" stroke forged 4340 crankshaft (internal balance possible)
6.800" H-beam rods with 7/16" ARP 2000 bolt (Centralign Design)
Custom RaceTec/Autotec flat top Pistons, add $75 for dome/dish
Total Seal ring set
King rod & main bearings
Rollmaster billet timing chain set (CS3130) $129 value
Assembly comes balanced ($250 Value)
SALE PRICE: $2600
http://www.tmeyerinc.com/ProductDetails.asp…
Rotating Assembly #2 available in 1-2 months...
351 Cleveland stroker (408 cubes)
4" stroke forged 4340 crankshaft (internal balance possible)
6" H-beam rods with 7/16" ARP 2000 bolt (Centralign Design)
Total Seal ring set
King performance rod & main bearings
Rollmaster billet timing chain set (CS3031) $129 value
SALE Price: $2650
351M/400 H-beam connecting rods
H-beam connecting rods to replace factory rods.
Stock length, stock pin size, press fit.
SALE PRICE $599
More products coming soon...
13217540_10154196071283762_2898061187153
13243694_10154196072713762_1242232908351
Edited by Rockatansky - 30-July-2016 at 2:26AM
