Newbe |
Post Reply | Page 12> |
Jedi
New Member Joined: 12-February-2020 Location: Kelowna B.C. C Status: Offline Points: 28 |
Posted: 12-February-2020 at 1:08PM |
Hi Forum Members,
My name is Jim and I hail from British Columbia, Canada Currently working on a 1970 Mercury Cyclone Spoiler 429CJ Hope to gain some members knowledge on these cars Cheers Jim
welcome jim! post some pics when you get upgraded
Welcome aboard Jim! I have upgraded you so you have full privileges and can post pictures. We'd love to see that Cyclone it sounds great.
handsofstone
Welcome. Yes pics.
Jedi
I tried several times but no luck
Jim
did you view "how to post pics"? view the tutorial video i did there... thats for uploading from a computer but from a phone is similar
Jedi
Tried a few times with no luck, I did read through again
Jim
kychevyguy
Welcome to the forum.
JT, USAF Ret./Architect
handsofstone
If you leave this box in reply, it won't work.Also, turn off screen rotation if on a droid phone.
Jedi
Thanks, but I don’t have that little box
Jedi
I’m getting a preview picture, but still can’t post
Jim
handsofstone
Below the oreview are you clicking OK? Once you do that then you should be able to post reply. It took me a while to figure it out.
JackC
New Member Joined: 15-May-2019 Location: SoCal Status: Offline Points: 21 |
Welcome Jim!
if you're seeing it but it don't post you must be missing a step???
Jedi
I agree, maybe something to do with size
Edited by 72FordGTS - 14-February-2020 at 9:55AM |
You uploaded the photo fine, I added it to your post. Nice Cyclone!
Try watching the tutorial video we have in the how to post photos thread. If you see the preview of the photo, all you should have to do is click ok and it should post in the text box.
handsofstone
Definitely nice.
Very nice. Not too many left.
Jedi
Hi Forum Members, just came back on the site and see that my picture finally posted. Story on the car is it belongs to my Uncle from Vancouver, he bought the car brand new but it hasn’t been driven since 1989. I told him if he wanted I would come down from where I live pick the car up and bring it home. I’ve been puttering away on it for a couple of months and hopefully I might have it running this week. Cheers Jim
handsofstone
Make sure it manually turns over. That is a long time for exposed cylinder walls to be sitting without protection. Cracking a piston would suck.
Jedi
I’ve had the heads off and rebuilt, the engine turns over quite nicely, I also installed new timing chain and gears
For sure I’ll have my fingers crossed
handsofstone
Excellent. Keep on keepin on.
Jedi
Udate
I got the 429 CJ running today, started right up but wouldn’t idle down, I think a little adjustment on the carburetor will help, sounded great and had good oil pressure. I’ve got a small coolant leak on the water pump, hopefully not a real big fix, I dread the thoughts of having to pull the timing chain cover to fix this problem as the water pump is bolted to it. Overall quite happy with my progress for a car that hasn’t run in thirty years Jim
handsofstone
Why would you have to pull the timing chain cobec?
Jedi
Apparently the aluminum timing chain covers can get corrosion on them and the water pump bolts to the cover. Hence the coolant leak is actually caused by the timing chain cover and not the water pump itself
handsofstone
Makes sense. Fingers crossed for ya.
if you try to tighten or loosen the bolts and it don't feel right stop! sometimes the long bolts through the aluminum cover rust and corrode if any are you can heat the bolt up and burn out some corrosion so you don't snap a bolt off
Jedi
Hi There,
I got some things sorted out today, engine runs good with no coolant leaks, super throttle response. It’s currently idling at about 1000 RPM, part of the problem is I have the timing set at about 20 BFTDC. Tomorrow I’ll bring the timing back to 10 degrees and check the PCV, hopefully I can get the idle down to about 700 RPM Starting to get excited about getting this old Cyclone out for a drive, hopefully in the next week or so Cheers Jim
Jedi
Update,
I took the Cyclone out for a shakedown cruise today, it ran pretty well with no issues, well except for one. It’s pretty loud though, I’ve ordered a new set of Proflow mufflers for it, should be here next week, right now it has an old set of burned out mufflers with no tailpipes. I guess the one small issue is the horn doesn’t work, it has one of those horn rings that you squeeze with your thumbs on the inside edge of the wheel itself. That can be a next winter project, maybe someone can chime in if they know anything about this type of horn button. Cheers Jim
handsofstone
Most likely the horn itself is the problem. Check the fuse then unplug the wire from the horn and hook it to a test light.
