  New Posts New Posts RSS Feed - NorthElites 1976 project
 Post Reply Post Reply Page  <1234 13>
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-March-2015 at 12:20PM
. I truly admire your talent, .
what the cutting part?Shocked
sorry joe, i just couldn't resist!LOLLOLLOL
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 23-March-2015 at 12:58PM
I noticed that triangular part at the end...that would be cool to see as an actual window.
1994 Mark VIII
Retired 60s NHRA Anglia
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 24-March-2015 at 12:59AM
Lol, John.
Griffin, I thought the same thing when I saw that.
1972 GTSquire Wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 24-March-2015 at 10:07AM
Didn't some of the 74-76 Gran Torinos have something like that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2015 at 2:18AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2015 at 2:26AM
I mean as three separate windows. Just a thought.
1994 Mark VIII
NorthElite View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthElite Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2015 at 7:23AM
Time to close the cowl !
Last look to inside... I hope that I remeber to take unnessary parts out...Tongue
I paint my cowl top sheet with epoxy primer after sand blasting it.
And put urethane coat inside...
Start to welding it... It was quite huge part to weld. I make only small steps and try to take care of the heat.
After sanding it's just fine to me. We can see results after painting. I don't like put too much filler here Ouch
I have complete cowl now Tongue ...and You can now also see color of the Cusi3 welding. Wink
Gran Torino LS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gran Torino LS Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2015 at 8:12AM
Very nice body work! Awsome! Thumbs Up
Viktor
Save the V8 monsters!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2015 at 11:59AM
just curious why you didn't cut the spot welds out and plug weld it back on? that's how i did mine
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2015 at 12:00PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2015 at 1:13PM
NorthElite wrote:
"...and You can now also see color of the Cusi3 welding. Wink"
Cusi3 welding? More or less brazing with a MIG? Let us know how it works out, it LOOKS like a good method. I've used brazing rod with a Jeweller's torch on rust pinholes and small repairs with good results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthElite Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2015 at 7:38PM
Johnny, Your way is the best way to do it Wink
My time was running out day before blasting the body. I own one of the most dangerous tool and I use it again Sleepy It take only five minutes to open the cowl with my Shinano Saw. So, You understand why I say that this Shinano Saw is dangerous thing. This saw is extremely fast and easy to use. I know some unfinished projects witch are cut in thousands of pieces with that saw Cry You must realised that welding it all back together take lots of time and won't be always easy.
I do CuSi3 0,8mm welding wire with MIG and Argon gas. Seam is tight and no holes at all. Sanding is very easy and it wont rust. BUT It isn't hard like a steel. You can use it most of all bodywork's, but never with frame or heavy load spots.
Here is some information:
http://www.ceweld.com/en/content/cusi-3-welding-wire-mig-brazing
Edited by NorthElite - 31-March-2015 at 7:53PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2015 at 1:28AM
ok, i bought one of those little saws to use on my torino works good, i'll ckeck out the welding, looks interesting!
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthElite Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2015 at 7:02AM
Epoxy on...
Ok, It need some filler on, but I can live with that Smile
Then I make one fast and small corner...
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthElite Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2015 at 6:32AM
Hi again. I finally sealed the cowl and now I working with wheel houses.
With left wheel house was lots of to do, but it is done now Tongue ( There is much more to do on the right side Angry )
Well, my favorite corner was this one
One home made part again Smile
This one also Wink
Thanks for watching Smile
-NorthElite
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2015 at 6:55AM
Clap looks great! what did you use to form the edge of the wheel lip, one of those shrinker/stretcher things like eastwood sells?
51088 - Shrinker/Stretcher Combo Set-Two BodiesTwo Jaws
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthElite Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2015 at 7:01AM
Yes. Just tools like that. I love them.
I have shrinker/stretcher with stand like this
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2015 at 8:10AM
awesome, good to know! i just might have to buy one Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthElite Quote  Post ReplyReply Direct Link To This Post Posted: 30-July-2015 at 8:07PM
I have worked with rear right wheelhouse and wheel lip. I uploaded some new pictures Smile
Some one had make some quick repair here Dead
I like to make it good enough to me.
New metal in there...
And some metal out too...
And it starting looks good Tongue
Wheel lip need some attention too Confused
And same work to do in and out...
And it is OK to me. I put some filler later on it Smile
With the wheel house was lots of to do.
Primary coat on and some filler too. It looks OK to me now Tongue
-NorthElite
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthElite Quote  Post ReplyReply Direct Link To This Post Posted: 30-July-2015 at 9:00PM
Next I install my used and nice floor pans. I have already sand blasted and painted them with epoxy primer. I think this is just fun to fit them to the right place and weld it Tongue
- NorthElite
