  New Posts New Posts RSS Feed - Oil Pan Gasket Replacement
GPapaKim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GPapaKim Quote  Post ReplyReply Direct Link To This Post Topic: Oil Pan Gasket Replacement
    Posted: 31-May-2018 at 5:30PM
Anyone have a good procedure for replacing the oil pan gasket. Got under it today and couldn't reach all of the bolts with the Frame right below the middle of the pan. I'm sure I could get it out by removing the fan shroud and a couple of tubes and but I can't get to some of the bolts.
Help
GPapaKim
P.S. for whoever asked. I am in Maricopa, AZ. About 20 minutes south of Phoenix west of the I10.
Edited by GPapaKim - 31-May-2018 at 5:32PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 06-June-2018 at 8:12AM
If you don't have room to scrape the old one off of the pan and block, I would just remove the fan shroud and motor mount bolts. Then carefully jack the engine up enough to put some hardwood spacers between the frame and motor mounts. There should be enough room. And you may need to customize a 7/16 socket and combo wrench. We had to make tools work quite often at Aamco and sometimes all the bolts never made it back into those areas. I wouldn't advise leaving out any pan bolts.
And like valve covers, a ball peen hammer was handy when it came to putting a little low spot on the mating surface for extra "pull" when tightening the pan or cover down.
I realize the hammer won't work in this case but is something to keep in mind for
another day. Are the gaskets still cork? Haven't put a pan on since 1981.
Edited by handsofstone - 06-June-2018 at 8:13AM
-John
72 GTS S Code
2015 Super Cab F-250
Post Options Post Options   Thanks (1) Thanks(1)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 06-June-2018 at 9:49AM
Fan shroud out.
Raise engine until it hits tunnel.
shim at mounts to support
remove starter
unbolt pan and drop to crossmember
unbolt oil pickup, drop into pan
weasel pan past crank throws
remove old gaskets and clean flanges
put pan back under engine
reinstall pickup
attach pan gasket to pan flange with dental floss thru holes
start all pan bolts
remove dental floss
tighten bolts
reinstall starter and lower engine
fill engine with oil (Very important)
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 06-June-2018 at 9:52AM
Excellent! Hope I never have to do it.
And you have the added bonus of being able to tap each hole down with a ball peen.
Edited by handsofstone - 06-June-2018 at 9:54AM
-John
72 GTS S Code
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 06-June-2018 at 10:27AM
i'd find a way to snug it down with 1/4" drive and extensions  / universals before doing it in the car
remove the engine mount bolts and lift it up if you have to, pulling the motor out and doing a complete re-seal is the Easy Way
because you won't be chasing the next leak in the car next week
heck i'd break the engine down and do the head gaskets valve stem seals, freeze plugs, timing set & front trans seal ...
then re-assemble with a complete gasket set
take the fix or repair daily out of owning a Ford ;)
Edited by Rockatansky - 06-June-2018 at 10:31AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 06-June-2018 at 11:04AM
You forgot the rope seal.
-John
72 GTS S Code
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 06-June-2018 at 12:53PM
update to neoprene, it's in the gasket set Thumbs Up
