  New Posts New Posts RSS Feed - Oil pump primer from old distributor
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Topic: Oil pump primer from old distributor
    Posted: 15-January-2017 at 10:33AM
Guys, hope to be lighting off my 460 in a few weeks and I have an old distributor that I want to break down and use as a oil pump primer. Anyone ever made a priming tool form an old 460 distributor? Any tricks and suggestions on how to proceed?
THANKS IN ADVANCE
Post Options Post Options   Thanks (1) Thanks(1)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2017 at 10:51AM
I did the same thing with an old 460 points distributor. Just use a punch/drift to drive the pin that holds the cam gear in place(remove gear) and install like regular distributor. I cannot remember the size of the socket I used to turn the shaft, it was a deep dwell 1/2" drive, used both a socket wrench(while on the engine stand) and a cordless drill with a 1/2" socket adapter)once engine installed prior to "real" distributor installation. Make sure you upgrade the oil pump drive shaft to a Ford Motorsport unit AND do not forget to install the collar that keeps the oil pump drive shaft "in place" if ever you remove the distributor. Good luck.
Edited by aquartlow - 15-January-2017 at 10:52AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2017 at 11:47AM
Do you need the distributor? I know that you do with a chevy, because the distributor body routes oil around it from somewhere to somewhere and it won't prime properly. Ford smallblocks don't need the distributor, but IDK about 460.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2017 at 1:54PM
i made one for a SBC by removing the gear teeth, lathe works great, or you can grind them off
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2017 at 10:15PM
Really don't know if the entire distributor is necessary or not but I have an old one on hand so I figured I was part of the way there.....
CJ, aren't the teeth pinned to the shaft?
Edited by TV 2M8O - 15-January-2017 at 10:17PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-January-2017 at 2:26AM
yes on a ford i think you can just remove the gear, end of the shaft drives the pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 16-January-2017 at 5:53AM
all you need is a speed handle, 3/8" extension, 1/4" adapter & a 5/16" socket
crank the oil pump drive shaft counter clockwise with the speed handle tool
turn the crank bolt 90*, oil some more
repeat until you have oil flowing at each rocker
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-January-2017 at 6:35PM
that's how i primed my windsor, but i used a 1/2" makita drill in reverse
rancheromac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rancheromac Quote  Post ReplyReply Direct Link To This Post Posted: 23-May-2018 at 3:44AM
moroso makes one for $8, why spend time making one ?
