  New Posts New Posts RSS Feed - OK, another floor question. Torino based vs. LTD
russosborne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Topic: OK, another floor question. Torino based vs. LTD
    Posted: 09-October-2017 at 9:18PM
Someone is parting a 78 (I think, might be 77) Ranchero and I am wondering if the floors are compatible or if they are so different it wouldn't be worth trying? Main interest is the floor, but if the firewall is close that would be something else to think about.
Thanks
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 10-October-2017 at 12:23AM
floors should be identical except for updates from 1972. when i swapped complete roofs 78 onto a 72 i found that the shoulder belt mount locations were moved and inner structure beefed up
everything through the middle is compatible just the outer skin changed
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-October-2017 at 3:01AM
should work fine
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 10-October-2017 at 10:22AM
I'm going to guess a rear Ranchero floor pan is more similar to a 4 door car. I used one in my 72 but had to remove three or four inches out of the middle to shorten the pan.
13 Taurus SHO "Mr Pig"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 10-October-2017 at 10:35AM
ranchero pan is the same as a wagon pan thru the back seat. 4 door is same wheelbase as wagon so all 3 should be the same until the rear axle area. LTD II should work fine, as it is a reskinned Torino and not structurally like fullsize LTD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 10-October-2017 at 8:27PM
Thanks, guys.
I emailed the seller to see if he is interested in selling the floor.
Russ
