  New Posts New Posts RSS Feed - P/S Cooler Detailing
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Topic: P/S Cooler Detailing
    Posted: 19-November-2018 at 12:43PM
I am ready to install my power steering cooler soon.  It needs to be cleaned up and detailed.  I have soaked it in parts cleaner and this is what it looks like now below.  It is solid, just needs the paint stripped and reshot.  Anyone have any suggestions on how to clean it up/prep for paint?  Keep in mind the fins are pretty fragile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-November-2018 at 1:35PM
 send me that stool it's laying on, and i'll tell youLOL
 i'd say remove the paint with spray paint stripper... no blasting! the tubes and fins i don't think are steel so shouldn't be any rust on them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 19-November-2018 at 1:55PM
Try this stuff(not my pic),
Image result for Rust-Oleum Aircraft Remover Aerosol
I used it to remove powder coating from an intake manifold.
Edited by aquartlow - 19-November-2018 at 1:56PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 19-November-2018 at 2:24PM
Thank guys, stripper should work the best..  I think the fins might be brass?  Maybe even the tubes.  The brackets are just steal though.
Will those strippers be okay on brass?
And John, you're not getting my shop stool!!
Edited by 72FordGTS - 19-November-2018 at 2:24PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-November-2018 at 6:35PM
those strippers shouldn't hurt brass... you just need it to remove the old paint then wash it off with water Wink  if you need to blast the steel bracket... wrap the rest with duct tape to protect it.
 when repainting it, spray just enough to color it evenly, don't lay it on thick!
 a reliable radiator shop told me that as i sprayed a radiator with several nice coats of urethane auto paint... he told me that it won't dissipate the heat as good and that he had a hell of a time removing it in the hot tank EmbarrassedLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-November-2018 at 6:36PM
re: the stool... can't blame a guy for trying LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 19-November-2018 at 11:27PM
There's always a good time to be had when a stripper is involved...…….especially when removing paint Wink.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2018 at 12:16AM
Clap  HAHA...well said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2018 at 10:45AM
i wonder if soda blasting would / could be gentle enough?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2018 at 10:54AM
Dip it in brake fluid.
2005 F-150 STX 4.6, 3.55 LSD
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2018 at 12:07PM
To update this thread, I did end up stripping the paint with paint stripper. It worked fairly well then it require prep with sand paper and wire brushes
In the end it came out pretty good I think.
Here it is stripped:
Here it is painted:
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2018 at 1:36PM
 Thumbs Up Big smile
This page was generated in 0.079 seconds.
