paint chip protection |
1973gts
Senior Member Joined: 05-March-2018 Location: Grand Rapids Mi Status: Offline Points: 615 |
Posted: 08-January-2019 at 4:58AM |
I remember on my original white 73 GTS that it suffered alot of paint chipping especially behind the rear wheels. I was told by my body/paint man that the newer paints are much harder and chipping will not be near the problem it once was. I am also planning on going with a wider tire than stock which will probably increase the amount of debris thrown up. I am curious if anyone has any opinions on this and also if anyone has applied anything like SEM's chip guard paint behind the wheel wells. thanks - dave
Dave - 1973 GTS N code
keeping all your paint coats (primer,paint, clear) to a minimum helps to chip less 3M makes dome clear vinyl stuff that helps. most factory cars have some in chip prone areas.
many of the paint manufactures have a urethane spray on chip gard stuff that can be painted over but it has a "textured" look to it |
Thanks(1)
Mudflaps.
Mudflaps with chrome naked lady silhouettes.
My car had mudflaps since day one. They were installed on it when it was brand new by the dealer. It's helped save the paint over the years. They are the nicer polished stainless/rubber ones.
Otherwise, the modern 3M type clear plastic would be the best bet. My truck has it on the box sides in front of the wheel openings and they work well. |
1973gts
Thanks for the responses, I like the clear plastic film idea, will be checking into that. Vince, would you possibly have a picture of your car with the mudflaps on it you could post? Like to see how they look and would definitely consider those. thanks again
speaking of mud flaps... something i've done on a couple of my cars... made flaps from 1/8" thick clear vinyl (like the hanging things in the doorway of a cold storage place) with 3 snaps riveted through the vinyl and the screw type matching male snaps mounted to the rear edges of the front fenderwells! (yes, i said FRONT)
not noticeable going down the road, then snap them off at a show put em in the trunk why on the front you ask? because you drive through rocks on the road first with the front tires! Edited by californiajohnny - 08-January-2019 at 5:00PM |
MrSmog
the body lines of the 72-76 cars sure make everything behind the wheels easily hit with debris from the tires. I have some small stainless steel "spat" style mud flaps I might use but just hate the idea of mud flaps so much.
oh i do too!
MrSmog
I do like your idea a LOT though, way to think outside the box.
Here's a pic. Since the car has always had them, they don't bother me. The rubber is getting a little rough on them since they are nearly 50 ears old so I may replace them. But they have saved my paint.
1973gts
Thanks, Vince, those do look really good. Did some checking today to see if I could find something similar but couldn't. If you do find them I'd appreciate it if you would let me know where at - thanks- dave
yeah i haven't seen that style in a few years... but i'm sure there's some around they were popularback in the 80's and 90's
MrSmog
you can find them on ebay, I got a few sets this past summer just in case I wanted to use them on my formal and fastback. maybe I'll use the snaps so they are removable..................... PS-don't buy unless 20.00 or so a pair, some that are priced on there are INSANELY priced but there are cheaper ones on there if you hunt.
Edited by MrSmog - 10-January-2019 at 3:10AM |
MrSmog
just search for "muscle car stainless steel flap guard" and they'll come up.
