  New Posts New Posts RSS Feed - Paint code and dso  code
Lrw2798 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lrw2798 Quote  Post ReplyReply Direct Link To This Post Topic: Paint code and dso code
    Posted: 20-September-2018 at 11:25AM
On the door jamb of my car it has no paint code and I believe the dso code indicates that it was supposed to be shipped overseas can anyone help
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 20-September-2018 at 12:12PM
This will help you decode the tag here:
Here is for the VIN:
It looks like you because your car is an export it has some unique codes.  I'd suggest getting a Marti Report to get the original colour and the other codes figured out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lrw2798 Quote  Post ReplyReply Direct Link To This Post Posted: 20-September-2018 at 12:20PM
I'm planning on it and I cant find a build sheet in the car under the rear seat and someone started ripping the carpet out at some point and time so I guess I might be out of luck when it comes to that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 20-September-2018 at 1:45PM
I have had good luck using this place to help find correct colors, paint codes and/or sheens, hopefully it will help you as well: http://www.autocolorlibrary.com/
Edited by aquartlow - 20-September-2018 at 1:52PM
