Paint code, HELP! Copperhead's original color? |
Author | |||
M Casey Stock
Senior Member Joined: 02-September-2015 Location: Meridian MS Status: Offline Points: 233 |
Posted: 20-June-2017 at 4:06AM |
What the heck kind of paint code is this? And why can't I find it listed? Surely one of the Gurus on here has a full factory paint code chart.
This the original paint on Copperhead before the upgrade to PPG Copperhead met. Before I ever touched it in a different light. Edited by M Casey Stock - 20-June-2017 at 9:50AM |
1975 Gran Torino, Copperhead
http://forum.grantorinosport.org/75-gran-torino-soft-restoration-copper-head_topic15137_post169060.html?KW=#169060 |
72GTS351CJ
I guess it was a .....J or a .....T...Looks like the tops of all the numbers and letters are faded
72GTS Clint Eastwood Special
M Casey Stock
5J is Ginger Glow in 1974 (according to some sources) which is a Drk Brown color (kinda Root beer colored) and the same color in 1975 is called Dk Ginger Met. 5T is a closer color, in 1975 is shows to be Saddle Bronze Met, which is a closer match, but I really don't think the top is faded to where you couldn't see any signs of the top of the "T" at all, and then there is still the "underscore" what is that all about? |
M Casey Stock
Here is a blown up picture of the label. the top of the T could be completely gone, or maybe it just slipped down the label and now looks like an underscore
gpd294
Senior Member Joined: 18-September-2008 Location: Dallas, Texas Status: Offline Points: 2180 |
51 5395-A Ginger Bronze Met.
M Casey Stock
Okay, I knew it was on here somewhere, I looked and looked last night. I noticed the link was to a 74 model, mine was built in 74, but was sold as an early 75. I wonder if the codes are the same? I still can't find that page without your link. |
gpd294
I was thinking the same thing, but I went with the manufacturer date on the tag so I believe it to be correct. I had to Google "1974 Ford Gran Torino 51 paint code" and it took me to the GTS site... :)
Power Surge
It's 5T. That's not a 1. Look at the other "1"s on the sticker.
Sal Mennella
gpd294
Ya know what, I think you are right...I stand corrected. 5T 5145-A Saddle Bronze Met.
Edited by gpd294 - 20-June-2017 at 6:32AM |
M Casey Stock
Any clue about the "underscore" ? |
M Casey Stock
So if I'm looking at this correctly, for it to be a "GLOW" paint option in 1974, it would have to have an * after the 5J for it to be "Ginger Glow" otherwise it is Dk Ginger Met. Correct?
Edited by M Casey Stock - 20-June-2017 at 6:43AM |
stanman
Remember we're talking 1972 technology. Probably a typewriter type printer. Easy to get blurred or incorrect letters and numbers.
M Casey Stock
True, would have loved to had seen the label on unlovedford's 75 GTS he scrapped out. I got the passengers fender off it and it was an exact match. |
M Casey Stock
Power Surge
Yep....considering the entire top of the T is missing, I bet you that stamp was probably bent. So you lost the top of the T, and caught the bottom edge of the stamp plate. |
Sal Mennella
M Casey Stock
Awesome! that would for sure explain the "underscore" |
M Casey Stock
Sorry I posted this in the wrong spot, I just now noticed it. BUT!! I'm so glad you guys just picked up and helped without a hiccup. It's greatly appreciated
GTW
Senior Member Joined: 21-January-2012 Location: SC Status: Offline Points: 5784 |
A Marti Report would help you know for sure.
1973 Gran Torino station wagon 1972 Gran Torino 4 Door 1971 Maverick 2 Door |
Power Surge
The buck tag should also have the color code.:) |
Sal Mennella
aquartlow
This link/site has been very helpful for me in the past with not only paint colors, but also interior colors/sheens as well as vinyl top colors. Probably too late to join in, but hope this helps.
M Casey Stock
It's more of a curiosity thing for me and a Marti report is not worth the money on a car like mine. I already know I don't have anything special Plus I know of at least one of those reports that the paint color description is wrong. |
M Casey Stock
Is that the metal tag under the hood that is also painted? |
Power Surge
Color code will be on the buck tag.....and also should be on the build sheet that's usually stuffed in the rear seat springs.
Sal Mennella
Power Surge
Yes....buck tag contains all the build info for the assembly workers so they know how that particular car should be built.
Sal Mennella
M Casey Stock
Okay, no metal tag under the hood and I've already restored the car, interior and all, and unfortunately someone beat me to all the build sheets. I've been behind every door panel, under all the floorboards insulation pads and rear seat hiding places. Nothing :( its okay, i think we are pretty sure it's a 5T. Would have been cool to have found the metal tag since I knew all the paper build sheets were gone.
Edited by M Casey Stock - 20-June-2017 at 2:51PM |
