  New Posts New Posts RSS Feed - Paint code, HELP!  Copperhead's original color?
M Casey Stock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Topic: Paint code, HELP! Copperhead's original color?
    Posted: 20-June-2017 at 4:06AM
What the heck kind of paint code is this? And why can't I find it listed? Surely one of the Gurus on here has a full factory paint code chart.
This the original paint on Copperhead before the upgrade to PPG Copperhead met.
Before I ever touched it in a different light.
Edited by M Casey Stock - 20-June-2017 at 9:50AM
1975 Gran Torino, Copperhead
http://forum.grantorinosport.org/75-gran-torino-soft-restoration-copper-head_topic15137_post169060.html?KW=#169060
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 5:17AM
I guess it was a .....J or a .....T...Looks like the tops of all the numbers and letters are faded
72GTS Clint Eastwood Special
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 5:40AM
5J is Ginger Glow in 1974 (according to some sources) which is a Drk Brown color (kinda Root beer colored)  and the same color in 1975 is called Dk Ginger Met.  5T is a closer color, in 1975 is shows to be Saddle Bronze Met, which is a closer match, but I really don't think the top is faded to where you couldn't see any signs of the top of the "T" at all, and then there is still the "underscore" what is that all about?
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 5:50AM
Here is a blown up picture of the label. the top of the T could be completely gone, or maybe it just slipped down the label and now looks like an underscore LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 6:03AM
51 5395-A Ginger Bronze Met.
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 6:17AM
Okay, I knew it was on here somewhere, I looked and looked last night. I noticed the link was to a 74 model, mine was built in 74, but was sold as an early 75. I wonder if the codes are the same? I still can't find that page without your link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 6:20AM
I was thinking the same thing, but I went with the manufacturer date on the tag so I believe it to be correct. I had to Google "1974 Ford Gran Torino 51 paint code" and it took me to the GTS site... :)
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 6:29AM
It's 5T. That's not a 1. Look at the other "1"s on the sticker.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 6:31AM
Ya know what, I think you are right...I stand corrected.
5T 5145-A Saddle Bronze Met.
Edited by gpd294 - 20-June-2017 at 6:32AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 6:37AM
Any clue about the "underscore" ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 6:40AM
So if I'm looking at this correctly, for it to be a "GLOW" paint option in 1974, it would have to have an * after the 5J for it to be "Ginger Glow" otherwise it is Dk Ginger Met. Correct?
Edited by M Casey Stock - 20-June-2017 at 6:43AM
stanman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanman Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 6:54AM
Remember we're talking 1972 technology. Probably a typewriter type printer. Easy to get blurred or incorrect letters and numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 7:19AM
True, would have loved to had seen the label on unlovedford's 75 GTS he scrapped out. I got the passengers fender off it and it was an exact match.
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 7:23AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 7:48AM
Yep....considering the entire top of the T is missing, I bet you that stamp was probably bent. So you lost the top of the T, and caught the bottom edge of the stamp plate.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 7:54AM
Awesome! that would for sure explain the "underscore" Clap Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 9:53AM
Sorry I posted this in the wrong spot, I just now noticed it. BUT!! I'm so glad you guys just picked up and helped without a hiccup. It's greatly appreciated Beer
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 9:59AM
A Marti Report would help you know for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 10:02AM
The buck tag should also have the color code.:)
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 10:46AM
This link/site has been very helpful for me in the past with not only paint colors, but also interior colors/sheens as well as vinyl top colors. Probably too late to join in, but hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 11:37AM
It's more of a curiosity thing for me and a Marti report is not worth the money on a car like mine. I already know I don't have anything special LOL  Plus I know of at least one of those reports that the paint color description is wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 11:38AM
Is that the metal tag under the hood that is also painted?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 11:39AM
Color code will be on the buck tag.....and also should be on the build sheet that's usually stuffed in the rear seat springs.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 11:40AM
Yes....buck tag contains all the build info for the assembly workers so they know how that particular car should be built.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Casey Stock Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 2:36PM
Okay, no metal tag under the hood and I've already restored the car, interior and all, and unfortunately someone beat me to all the build sheets. I've been behind every door panel, under all the floorboards insulation pads and rear seat hiding places. Nothing :( its okay, i think we are pretty sure it's a 5T. Would have been cool to have found the metal tag since I knew all the paper build sheets were gone.
Edited by M Casey Stock - 20-June-2017 at 2:51PM
