  New Posts New Posts RSS Feed - Parking brake route/mounts etc
Iain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Iain Quote  Post ReplyReply Direct Link To This Post Topic: Parking brake route/mounts etc
    Posted: 23-March-2020 at 12:55AM
Does anyone have pictures or a diagram of the parking brake cable mounting locations for an Elite? I have the cables on the car, but they are floppy. I feel like there may be mounting brackets missing or similar. Any help welcome on this, as I need to get it working as my driveway slopes!
Thanks,
Iain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 23-March-2020 at 1:50AM
I can try and get you one in a day or two when I have some time to search and scan the image (unless someone else posts something first).  If you have a factory service manual, I think it might be in there.  If you don't have the factory service manual, I'd recommend purchasing one.
Iain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Iain Quote  Post ReplyReply Direct Link To This Post Posted: 23-March-2020 at 7:58AM
Thanks for that. No rush if you can find anything. All I have is the Haynes manual, which is a bit useless for some things - especially this!
Factory manuals always the best I've found previously.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-March-2020 at 3:53PM
i have a 74 manual and i think they changed the cable routing in 75? somewhere on here joe tv2m8o posted something about this same issue with his 76...
Iain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Iain Quote  Post ReplyReply Direct Link To This Post Posted: 30-March-2020 at 1:26AM
I wound the most obvious adjustment nut I could find, which seems to have improved matters. Will give it some more though.
Is one press of the foot lever usually correct, or one and a bit?
Don't know what is normal, as am used to hand operated cars.
Thanks,
Iain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-March-2020 at 3:44AM
if it's holding tight and about only half way to the floor you're good
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 02-April-2020 at 1:26PM
Sorry for the delay.  See the diagrams in this post here:
I hope that helps.
Iain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Iain Quote  Post ReplyReply Direct Link To This Post Posted: 11-April-2020 at 4:09AM
I hope that helps.
Thanks for that, I had seen the earlier diagram somewhere before, but not the later one below it.
I gave it a good adjustment which has improved it. Still room for more but don't want it to be binding while moving. Need to jack it up to do it really.
