Pedal assembly removal on 72? |
soldmy72
New Member Joined: 21-July-2013 Location: ct Status: Offline Points: 25 |
Posted: 25-March-2021 at 11:58AM |
Its been a long time since I did this.
What is the procedure for removing the pedal assembly? Can it be done without removing the dash? |
72 GTS Q-auto...sold
73 'Chero Q 4 spd 72 GTS H-auto 72 GTS Q 4spd |
i've always removed them with the dash out but i think it can be done with it in, you'd need to remove the cluster and the column, and brake booster, the heater control cables run through a hole in the pedal assembly also. but with all that stuff removed i think it can be tilted turned and removed with the dash in place...?
i got mine out
So, the roof needs to come off first?
The Chevy guys are right, their cars ARE easier to work on! |
