  New Posts New Posts RSS Feed - Pedal bearing installation
armymn1984 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote armymn1984 Quote  Post ReplyReply Direct Link To This Post Topic: Pedal bearing installation
    Posted: 31-October-2017 at 4:58AM
so I recently put a bearing kit in for the pedals. What I did was cut the bushing off as close as I could to the pedal bracket. I then used a ball peen hammer and knocked the inside portion out. I retained the inside portion as i used it to align the bearing and housing. I put the shaft through to keep both the inner bushing and bearing centered while I tacked the bearing housing down. Repeat the same process for the other side. I Used TIG to weld it in but shouldn't be too hard to use MIG. Keep in mind it's a thin metal and overheating it will tend to warp the metal so take your time. I picked up the bearing kit from mustang steves online. It also comes with instructions on how to do it.
Airborne All the way!!!
This page was generated in 0.092 seconds.
