  New Posts New Posts RSS Feed - Phantom Tail Light Issue 69 Torino G
ScottHenshaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottHenshaw Quote  Post ReplyReply Direct Link To This Post Topic: Phantom Tail Light Issue 69 Torino G
    Posted: 03-December-2016 at 4:20AM
Hello all.  New to the group so nice to digitally meet you all.  I just purchase a 1969 Torino GT Fastback.
Car is running really good but last night on the free at night a couple people where flashing my with there headlights and someone pulled up and told me that I had no lights on the back of the car.   Odd thing is that every-time that I pulled over and walked back and checked the were working fine. Angry
All that lights in the car that I can see while driving never had an issue so problem must be related just to the back.  Thinking ground issue somewhere.  Right?   I will run out later today and do some more wiggling and looking in the trunk to see if I can find anything that is a clear issue.
I did change the 1157 bulbs and did a general inspection of wiring.
Any thoughts or ideas would sure be welcomes.
Scott
Scott Henshaw
1969 Ford Torino GT Fastback 351-4V
Regul8r 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r 2 Quote  Post ReplyReply Direct Link To This Post Posted: 07-December-2016 at 8:13PM
sounds like a ground or a wire connection from the front to the back is dirty, loose or corroded.
WELCOME to the Family!
Your profile is approved now
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2016 at 12:06AM
Typical for those is a ground, as Regul8r II posted. Make sure the bulbs and sockets are clean, and the ground for them is as well. They usually come and go as the car bounces over bumps. Also the springs in the sockets that press the contacts at the base of the bulb get weak.
2005 F-150 STX 4.6, 3.55 LSD
