  New Posts New Posts RSS Feed - pinto
pinto
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: pinto
    Posted: 09-October-2015 at 1:28PM
tried to tighten the ball joint to day. Found out you can't without any weight on the car.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-October-2015 at 1:45PM
try putting a floor jack under the edge of the arm by the ball joint, and lift enough to smack down on the edge of the spindle! the ball joint shaft should grab on the taper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 12-October-2015 at 9:02AM
Thanks to Dave I have scored a mustang oil pan.Major problem solved.Now to find a sway bar.
