POR-15 and Skin (My skin) |
texanrebel
Senior Member Joined: 13-June-2018 Location: Houston, Texas Status: Offline Points: 208 |
Posted: 28-March-2021 at 9:27AM |
I think I know the answer, but does anyone have the secret formula that grandpa used to get this wonderful stuff off of skin once it dries? I know acetone will mostly remove it when wet and semi-dried...and skin exfoliation...over a couple of weeks is the other method. I am about as fair skinned as it gets and it looks really bad.My painters coverall sprung some leaks and I'm wearing quite a bit of it and my wife thinks I need to call the manufacturer.
Thanks
ps - I saw on another forum that Pam cooking spray works - did not on me |
1972 Montego GT
1977 Mercury Monarch 1988 Ford Thunderbird Turbo Coupe |
Yellosn
Member Joined: 14-February-2020 Location: Eugene, OR Status: Offline Points: 134 |
WD-40?
Sugar skin scrub? (Works great for grease).
Troy Emerson
Eugene, Oregon 1972 GTS 4speed |
albo74
Senior Member Joined: 25-February-2006 Location: ME. USA Status: Offline Points: 616 |
tub of towels takes off a lot of stuff safely , but with POR I might try gasoline , in a well ventilated area
albos73gts
72 RS 351
Try something mild first before the serious stuff. How about engine degreaser, those are all mild compared to carb cleaner etc. I use that on parts sometimes when the grease is really bad and I need to use carb cleaner. Together those do better on parts than blasting a ton of carb cleaner and using more than one can. For a tough finish material like POR 15, it's going to take both time and agitation at the edge of the skin and material. You are not going to dissolve it from the skin, the chemicals that could do that would be soaking on the skin as well.
Edited by 72 RS 351 - 28-March-2021 at 4:15PM |
You really don't want to put any chemicals that would dissolve POR 15 on your skin. Vegetable oil and attrition are about it.
Rivercrest
Member Joined: 07-December-2019 Location: Manitoba Canada Status: Offline Points: 175 |
Here I have used " Simply Awesome " to remove everything from paint on my skin to bugs off my car grill. Sold almost exclusively at Dollar Tree stores. Found it first in the USA.
Bob
1974 Cougar XR7 with a 72 351C |
texanrebel
Just going to wear long sleeves and get some better coveralls. Thanks for all the suggestions
1972 Montego GT
If you are doing more, Baby oil/Sunscreen will help keep it from sticking in the first place. (Doesn't mean you have to turn yourself into a greased pig, a little does the job.)
