  New Posts New Posts RSS Feed - Prepping bare metal for epoxy and topcoat?
Grantorinosport351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Topic: Prepping bare metal for epoxy and topcoat?
    Posted: 21-November-2013 at 5:37PM
Ok soon I will be sending the torinos frame and suspension off for sand blasting, after I get it back I plan on 2k epoxy primer then 2k ceramic chassis black from east wood. What do I do for bare metal prep befor epoxy, I was thinking hit it with a red scotch brite then using after blast cleaner then spray epoxy then hit the epoxy (lightly) with a red scotch brite, dust it off, then spray top coat. What's your opinion?
~Bryan
72 gts h-code (formal roof)
67falcon
04 f250 ''the great white''
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 22-November-2013 at 2:28PM
i'd blow out the frame with air when you get it back from the blaster( sand gets in everywhere!)then you can use a metal prep over it, then use a self etching epoxy primer like ppg DP90. 1 light "tack" coat, followed by 2 full "wet " coats. then you could use red scotch bright pad just to knock down any foreign particals  like dirt or a bug that got stuck in it, but you don't need to ruff up that primer to top coat it. then blow it off and lightly tack it off with a "tack rag" then top coat it.  p.s. DON'T EVER USE RED MECHANICS RAGS TO WIPE DOWN ANYTHING THAT YOU PLAN TO PAINT OVER!!
Montego01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Montego01 Quote  Post ReplyReply Direct Link To This Post Posted: 23-November-2013 at 12:45PM
I second that.
When I sprayed my frame after sandblasting, I just blew if off, wiped it down, sprayed 'sealer' which is a wet on wet type primer. No need to sand this sealer. then sprayed my semi-gloss black over it. you can see pics of the results in the link on my signature.
Scott
72 Montego GT 429 build thread
1966 Chevy C10
1973 Montego MX
2004 Bonneville GXP
