Spacer Plate GRAN TORINO 73
Forum Name: Small Block Forum
Forum Description: 221, 255, 260, 302 and 351W engines
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=14063
Printed Date: 19-April-2024 at 7:09AM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Spacer Plate GRAN TORINO 73
Posted By: jessie
Subject: Spacer Plate GRAN TORINO 73
Date Posted: 09-July-2015 at 10:58AM
Hi,
I'm from France (Paris) I've bought a very nice 73 Gran Torino Fastback 351 Cleveland 2bbl, almost a year ago.
I need to replace my spacer plate, it's very used, tried ebay and rockauto but nothing...Impossible to find one for the moment, any suggestions please ?
Thanks in advance.
Posted By: californiajohnny
Date Posted: 09-July-2015 at 2:45PM
are you referring to the one under the carb? welcome! post some pics of your car when you can
Posted By: Rockatansky
Date Posted: 09-July-2015 at 8:39PM
yes they are getting hard to find http://www.ebay.com/itm/Ford-truck-2-barrel-egr-valve-and-spacer-plate-/191623537056?hash=item2c9da721a0&vxp=mtr" rel="nofollow - http://www.ebay.com/itm/Ford-truck-2-barrel-egr-valve-and-spacer-plate-/191623537056?hash=item2c9da721a0&vxp=mtr http://www.ebay.com/itm/1977-1979-Lincoln-Continental-Mark-V-2-Barrel-Egr-Valve-Spacer-w-EGR-400ci-Ford-/171828463909?hash=item2801c64925&vxp=mtr" rel="nofollow - - http://www.ebay.com/itm/1977-1989-Ford-Mercury-Spacer-Plate-Valve-2-Barrel-Ford-D8AE-9D448-A1A-EGR-/201291351940?hash=item2edde64784&vxp=mtr and be aware that the gaskets involved are somewhat special, they need to hold up to exhaust temps this kit STANDARD MOTOR PRODUCTS Part # VG202 is available from http://www.rockauto.com" rel="nofollow -
Posted By: jessie
Date Posted: 09-July-2015 at 10:48PM
Yes the one under the carburetor
Posted By: jessie
Date Posted: 09-July-2015 at 11:27PM
Posted By: jessie
Date Posted: 12-July-2015 at 2:07PM
Thanks for the links Rockatansky, but is it gonna fit for my 73 Torino (351 5,8 Cleveland 2bbl) ?
Not the gasket for sure, have a look :
Date Posted: 12-July-2015 at 2:35PM
that's what they do, either clog with carbon or erode & burn through... that one you have there will never hold a gasket for very long as far as fitment you'll have t match up the pics as best you can, or try to go by the numbers. sometimes there are multiple part numbers that are basically the same & will work, or the same part but a different year thus a different number this new plate just showed up, looks like it should work for you? http://www.ebay.com/itm/FORD-MERCURY-NEW-CARBURETOR-EGR-SPACER-PLATE-CM2644-D7PZ-9A589M-/310620441648?hash=item48526bcc30&vxp=mtr" rel="nofollow - http://www.ebay.com/itm/FORD-MERCURY-NEW-CARBURETOR-EGR-SPACER-PLATE-CM2644-D7PZ-9A589M-/310620441648?hash=item48526bcc30&vxp=mtr the vacuum nozzle sticking out can just be blocked off with a rubber cap & hose clamp if you have no use for it, if it's even machined open? it looks like the one I linked above but the hose connector is not present so it may be solid / not machined here is one with the nozzle and the hose connection http://www.ebay.com/itm/1977-1989-Ford-Mercury-Spacer-Plate-Valve-2-Barrel-Ford-D8AE-9D448-A1A-EGR-/201291351940?hash=item2edde64784&vxp=mtr" rel="nofollow - http://www.ebay.com/itm/1977-1989-Ford-Mercury-Spacer-Plate-Valve-2-Barrel-Ford-D8AE-9D448-A1A-EGR-/201291351940?hash=item2edde64784&vxp=mtr
------------- 72 GT Ute
Date Posted: 12-July-2015 at 2:39PM
here's one that matches more closely to yours but may not ship worldwide http://www.ebay.com/itm/NOS-FORD-75-76-77-78-EGR-PLATE-LTD-MERCURY-GALAXIE-/200938739771?hash=item2ec8e1d83b&vxp=mtr" rel="nofollow - http://www.ebay.com/itm/NOS-FORD-75-76-77-78-EGR-PLATE-LTD-MERCURY-GALAXIE-/200938739771?hash=item2ec8e1d83b&vxp=mtr
Date Posted: 12-July-2015 at 6:53PM
nice car! looks to be in near perfect condition
Posted By: Nuggets
Date Posted: 12-July-2015 at 10:43PM
I might have a 2bbl spacer plate at home......cant remember if I sold it with the carb or not, will check on wednesday when I'm back
------------- Barnaby
Posted By: jessie
Date Posted: 13-July-2015 at 10:55AM
Nice ! Thanks Nuggets !!
5,8L 351 Ceveland (73 Gran Torino)
Let me know !
Posted By: jessie
Date Posted: 13-July-2015 at 11:05AM
Thanks CaliforniaJohnny !
Yes it is, saw it on ebay 2 years ago, I've missed it, but the car was sold in France !! So I asked to the new owner if he wanted to sell it, and now it's mine !
The interior is near mint condition, never replaced, it's impressive.
Posted By: albo74
Date Posted: 14-July-2015 at 11:46AM
OK so what I did was plane down the spacer plate to get a nice smooth surface , then tap the exhaust ports on the spacer and plug them off , lock tight , forget recycling emissions gasses , then use a gasket that was used prior to 72 , hooked every thing up to look stock , but no more of that dumping un burned fuel and exhaust gasses into the top of that engine . runs great .
------------- albos73gts
Date Posted: 14-July-2015 at 2:42PM
^^^ i was going to suggest that. plugging off that emissions crap, that's what i do on all my cars. that egr plate was a stupid design IMO (just for this reason!)
Posted By: jessie
Date Posted: 14-July-2015 at 3:29PM
Thanks Albo for your answer,
My english is not so good, so what do you mean excatly "tap the exhaust ports on the spacer" ?
And how do I plug them off ? With some material ?
I don't get it, sorry for this language barrier...
Posted By: Big Bird
Date Posted: 14-July-2015 at 4:04PM
Tapping means to cut threads into the hole so you can install a pipe plug. Your EGR spacer has the part off the back for the backpressure transducer. Those parts usually rotted apart inside of five years. If you don't have emissions testing, get a solid spacer.
Posted By: Montego
Date Posted: 16-July-2015 at 12:48AM
Jessie has my old car over in France.. I've found him the correct spacer for the 73/74 351C / 400
He also needs the flex hose that attaches to the end of the snorkel on the air cleaner.. It was there when I sent the car overseas, but its gone now.
He doesn't need the plastic at the other end.. just the flex hose itself.. Anyone have one in good enough shape to use?
Here's the car in Nov 2013 a few weeks prior to departing the USA..
Posted By: gpd294
Date Posted: 16-July-2015 at 2:40AM
Not to be negative Nancy here, but I had a hard time finding one of these. Luckily I ran across one on Ebay fairly cheap. I'm not sure why the Autopart stores just don't carry them anymore.
------------- Carlos....1975 Gran Torino Squire Station Wagon restored to look like a 1973 Torino Station
Date Posted: 16-July-2015 at 3:04AM
will this fit? http://www.tomsbroncoparts.com/product/air-cleaner-fresh-air-tube-66-77-early-ford-bronco-new?gclid=CLz7ltzo38YCFQYvaQodUY0MIg" rel="nofollow - http://www.tomsbroncoparts.com/product/air-cleaner-fresh-air-tube-66-77-early-ford-bronco-new?gclid=CLz7ltzo38YCFQYvaQodUY0MIg
Posted By: Nuggets
Date Posted: 16-July-2015 at 8:12AM
Had a look, unfortunately its gone. Only thing I've got left is the manifold and no one wants them
Date Posted: 16-July-2015 at 3:52PM
^^^that bronco one should fit? says 66-77 i think most of the cars were the same in the 70's IIRC
Posted By: jessie
Date Posted: 16-July-2015 at 9:53PM
Thanks for your help Big Bird !!!
Posted By: jessie
Date Posted: 16-July-2015 at 9:56PM
Hey Montego !!!
Thanks helping me !!!
The car's still the same, amazing ! I'll send some pics with the Eiffel Tower in the background as soon as everything is fixed !!!
Can't wait to drive this awesome car, she's sleeping in the garage...
Posted By: jessie
Date Posted: 16-July-2015 at 10:15PM
Hi Nuggets,
Thanks for looking !
Posted By: jessie
Date Posted: 16-July-2015 at 10:18PM
Hi Rockatansky,
Looks the same, just need to know if it's the right size...I've tried to find some infos, but nothing about the size.
Thanks.
Date Posted: 17-July-2015 at 3:23AM
I checked on the Autozone page, 1975 Torino uses the same part as 1975 Bronco I also came up with Dorman 96052 but that number is a dead end, these fresh air tubes may be going extinct This product is a fit for your: 1975 Ford Truck Bronco 5.0L 2BL OHV 8cyl Part Number: 96052 Alternate Part Number: P2516-25 This product is a fit for your: 1975 Ford Torino 5.8L 2BL 8cyl Part Number: 96052 Alternate Part Number: P2516-25
