Latch Pillar Seals
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=14305
Printed Date: 19-April-2024 at 7:57PM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Latch Pillar Seals
Posted By: Tillamook
Subject: Latch Pillar Seals
Date Posted: 26-September-2015 at 6:03AM
I'm new to this site and have read through many post on many different topics. This is a great source for information on anything pertaining to our cars! I read post each week looking for a specific part(s).
Does anyone know of where I can find a reproduced or usable set of the latch pillar seals for the quarter windows on a 72 Torino Fastback. They are located at the top of the latch pillar, where door latches, on the 1/4 panel right below the 1/4 glass, specific to the 72-73 Torino Fastback. It's the rubberized metal plate that prevents debris from falling in the front side of the quarter window. Any help on where I can find these would be great since my old builder tossed the ones on the car.
Thanks in advanced!
------------- Jeff B. '72 GTS FastBack 429
Posted By: californiajohnny
Date Posted: 26-September-2015 at 9:37AM
welcome! unfortunately those seem to be the only parts that are not reproduced there is a thread on here somewhere about coating them with plasi-dip in a spray can (available at home depot) i did that to mine, it came out ok, but i'd really like new ones. also there is a member here that is making some reproductions himself
Posted By: dave302
Date Posted: 26-September-2015 at 10:40AM
There is a member that is reproducing the seals. He believes that he has made them to the best of his current capabilities with what he had to work with. The molding process he uses are only as good as the original piece being molded. With that said he was unable to get a perfect specimen to start with and had to do the best he could using modeling clay and PlastDip to touch up the donated pieces. The finish is not identical from one to the other but not terribly noticeable unless you look close. I have put the pictures below, side by side so you can get a close look. He sprayed the parts with gloss black and clear sealer after molding and he thinks it made them look good. They are made with Urethane with a Shore D hardness rating of 80. This enabled him to closely replicate the rigidity of the part without a metal core. This of course means the area that comes in contact with the window is much harder than the original. Even though it is called a Pillar Post Quarter Window "Seal", he thinks that the main intent is to cover the hole between the door and window opening. He had said that "It is almost impossible to seal the opening completely from dust and dirt". He wants this fully explained so everyone can understand the pricing he will be using. For members he will be offering these for $40 each or $75 for a pair. Once he puts them on Ebay it will be $100 a pair or $50 each. No break on a pair. He is asking people to call him on the telephone if they wish to purchase these. The sellers name is Dan Frey, he is from Johnson Creek, Wisconsin. His phone number is: 9 Two 0- 2 Eight 5- 3 Eight 16 To send him a private message http://forum.grantorinosport.org/pm_new_message_form.asp?name=freyguy1" rel="nofollow -
Posted By: dave302
Date Posted: 26-September-2015 at 10:41AM
There is a picture below of the seals that he has reproduced.
Posted By: dave302
There is a picture below of a factory original seal to compare it to.
Date Posted: 28-September-2015 at 9:13PM
Californiajonny,
Thank you for responding fast, it's a relief to know this seal issue is still out there and under watch and people like yourself are helpful! I got a response from David302 fast also with good contact info. I'll give that member a try on reproduced seals.
Thanks again!
Date Posted: 28-September-2015 at 9:17PM
Dave302,
Thank you very much! I've scoured the web for these pieces and no luck. I used to have both my seals until I took my car to a builder that ended up going out of business when my care was in pieces, hence the missing pillar seal. I do have one and haven't decided 100% to use it or go with the reproduced set the gentlemen you mentioned makes. I will contact him and see where it goes!
Thank you for your help, ALSO!!
Posted By: dave302
Date Posted: 29-September-2015 at 8:31AM
Posted By: foote500
Date Posted: 29-September-2015 at 10:01AM
I sent a message to him about these two weeks ago-still waiting to hear from him.
------------- Marc German Shepherd Rescue 1967 Ford Fairlane 500, 390
Posted By: dave302
Date Posted: 29-September-2015 at 10:04AM
It would be better if you call him on the telephone. His phone number is: 9 Two 0- 2 Eight 5- 3 Eight 16
Posted By: Eliteman76
Date Posted: 30-September-2015 at 9:48AM
Dan is working on these. I will be buying a set.
------------- Andrew:GTS.ORG admin, '72 Q code 5 speed Restomod Pondering: #99Problems
Date Posted: 30-September-2015 at 3:12PM
I gave him a call earlier this evening and left a voicemail. He called me back in an hour or so. Had a nice conversation with him. He did say he will be working on these during the winter or when he gets more spare time.
Posted By: TV 2M8O
Date Posted: 01-October-2015 at 12:24AM
Yeah, I'm hoping for a set for the Tomato as well! Scored a NOS '74-'76 passenger side a few years ago but the driver side has been elusive......
TV 2M8O OUT JOE 1976 Gran Torino S&H season 2-4 Clone Project Blog: http://tv2m8o.blogspot.com/
Posted By: Big Bird
Date Posted: 01-October-2015 at 10:09AM
have you guys looked at the 72-76 T-bird/Mark IV to see if they are the same? they still turn up in junkyards from time to time and are usually kept up a lot better.
Posted By: foote500
Date Posted: 10-February-2016 at 2:18PM
Anyone know how this project is going?
Date Posted: 10-February-2016 at 2:51PM
I contacted him in the first half of January and he's had a rough winter with work. I know his priority is setting up his business full time which has occupied most of his spare time. I don't want to bother the guy when he has other stuff that's more important going on in his life but here in a week or two I'll give him a call to see how things are going. I'd like to get both sides from him so I'll update the thread when I find something out!
Posted By: foote500
Date Posted: 11-February-2016 at 1:46AM
Good enough.
Date Posted: 12-February-2016 at 4:22AM
Nice to know. Thanks for the update.
Posted By: TV 2M8O
Date Posted: 12-February-2016 at 4:33AM
He had also posted some info on the forum facebook page and I think a few pics of some of his first repops. I believe he's doing the '72-'73 seals first and then (hopefully) the '74-'76 seals.
Posted By: Rockatansky
Date Posted: 12-February-2016 at 2:59PM
they changed those too, what's the difference 1973 to 1974 ?
------------- 72 GT Ute
Posted By: TV 2M8O
Date Posted: 12-February-2016 at 5:38PM
The '74-'76 lack the deeper/smaller V notch since their quarter windows are fixed.
Date Posted: 13-February-2016 at 12:02AM
Ah-Ha! and Ranchero is probably different still?
Posted By: dave302
Date Posted: 13-February-2016 at 2:36AM
There is a picture below of a '72-'73 torino passenger side seal on the left side and a '74-'76 torino passenger side seal on the right side.
Posted By: TV 2M8O
Would a Ranchero even have them since there are no quarter windows?
Posted By: dave302
Date Posted: 13-February-2016 at 2:38AM
There is a picture below of a '72-'73 torino drivers side seal on the left side and a '74-'76 torino drivers side seal on the right side.
Posted By: dave302
Date Posted: 13-February-2016 at 2:40AM
The '72-'73 torino seals and the '74-'76 torino seals appear to be the same exact seals and maybe all you have to do is cut a slit down in the '74-'76 seals to make them fit onto the '72-'73 torino's.
And maybe you can build up the V notch area of the '72-'73 torino seals with something like a sealant product that is safe to use on rubber seals, to use them on the '74-'76 torino's.
Date Posted: 13-February-2016 at 4:23AM
I used RTV to repair a torn 1/4 window seal on my old 72 Sportsroof, it held until the very end I wish I knew how hard to find & $$$ some of those parts are back then now that I think about it, I may still have all that glass with the repaired 1/4 seal still on it
Date Posted: 13-February-2016 at 6:37AM
interesting... both the seals on my 74 have the deep slot???
Date Posted: 13-February-2016 at 6:51AM
better get some caulk lest Bigfoot fins his way in there IIRC those 1/4 windows that move go pretty much straight back anyway? are yours rollers or fixed CaJohnny?
Date Posted: 13-February-2016 at 7:46AM
they are fixed. when i was disassembling the car i looked at that area inside the quarter panel and thought about making the roll down, as i think joe was too, but just decided against it as i had more than enough things to do! just like the posts about using t-tops from a t-bird into a torino... thank god that didn't get posted until i was far enough along, that i couldn't do it or i probably would have
Posted By: Big Bird
Date Posted: 13-February-2016 at 10:04AM
On the formals 72-73, when the rear window opens, does it roll down completely or just move back a couple inches like the 72-76 Thunderbirds?
Date Posted: 13-February-2016 at 1:18PM
ilyes?
Posted By: green 72
Date Posted: 13-February-2016 at 3:17PM
On the 72 &73 formal tops they roll down some and then tip back. They do roll all the way out of sight into the quarter.
------------- Dan 1972 GTS Formal
Posted By: benzesrule
Date Posted: 14-February-2016 at 11:45AM
On my 73 Formal roof they are power and they go straight back.
------------- Phil
Posted By: foote500
Date Posted: 27-March-2016 at 1:57PM
Hope these hit the streets soon...
Posted By: forddude
Date Posted: 20-April-2016 at 3:13AM
hello, has anyone recently heard from the gentlemen or received a pair of his seals? I dont want to bother him if he's backlogged with inquires. Of course I could use a pair too and am considering rebuilding mine with some type of silicone or rubber spray.
Question#2: cant recall if there is a gasket that goes under the trunk emblem flapper? yes or no?
Comment#1: my qtr windows in my 72 do not go all the way down, maybe 2" inches of the window is still viewable when rolled down.
------------- 72 GTS sportsroof, original survivor 72 GTS formal, parted 96 Tbird 4.6, 18k org mi 13 Stang 5.0 6spd
Posted By: mcford
Date Posted: 20-April-2016 at 5:54AM
NO GASKET UNDER FLIPPER.
YOU'LL NEED TO GET IN AND ADJUST THE BOTTOM STOPS FOR THE WINDOW.
------------- Mike
Posted By: foote500
Date Posted: 24-May-2017 at 4:05AM
Anything ever come of this? I was expecting to by some.
Posted By: yellowsportwagon
Date Posted: 24-May-2017 at 11:59AM
Posted By: foote500
Date Posted: 25-May-2017 at 12:48AM
I will try to call him today.
Posted By: foote500
Date Posted: 25-May-2017 at 3:25AM
I just talked to Dan, he is really busy with his business and that is taking priority. He does not want to venture a guess when he will get back to it.
Posted By: forddude
Date Posted: 21-December-2017 at 3:59AM
-Anyone discover a solution for "Pillar Post Quarter Window" Seals? still need a pair for my 72 as mine are just the metal bones. -Not aware of any repops for any years. -Any success using seals from a later year and trimming?
Posted By: picon3
Date Posted: 21-December-2017 at 4:34AM
There is a good thread floating around about redoing the latch pillar seals.
Maybe here?
http://forum.grantorinosport.org/plastidip-on-latch-pillar-seals_topic2387.html%20P~" rel="nofollow - http://forum.grantorinosport.org/plastidip-on-latch-pillar-seals_topic2387.html%20P~
------------- 1972 GTS 351CJ-4V black/black
Posted By: forddude
Date Posted: 21-December-2017 at 4:55AM
Ah, thanks. following that post now. thought id have to do some sort of rubber spray technique to recreate the rubber on mine. or maybe build them up with foam, shape them, then rubber spray to seal them. "Flex seal" is available in liquid form.
Posted By: Compton
Date Posted: 27-March-2018 at 8:28AM
I am talking to a rubber molding company in NZ here about recreating these seals. Not sure on the cost yet but just gauging interest from members at present...
Have managed to source two set that will be used as donors as they are too brittle to be used on a vehicle
Will definitely be getting a set made for my car but if there is enough interest will consider getting a run done
Will probably be based on the 74-76 seal as a slot for the 72-73 cars can be cut into them easily enough....
Let me know if you're interested and what you'd be prepared to pay so I can see if it's cost effective
Thanks guys
Greg
Date Posted: 27-March-2018 at 3:46PM
yes the important thing is to have the metal in it so it keeps its shape and stays mounted to the body and to get a good intact mold from a set, then rework the mold so that the new ones don't have cracks molded into them from the originals i too was going to work on finding a company to take interest in repopping these as almost everybody needs them!!!!
Posted By: Compton
Date Posted: 27-March-2018 at 3:54PM
Getting the metal reproduced is the easy part and already sorted..trying to get the setup tooling cost for the mold down is going to be more difficult
Date Posted: 08-April-2018 at 2:55PM
I’m in for a set if you get them made.
Date Posted: 08-April-2018 at 5:14PM
greg i'd be interested if they are an exact repop of the originals as well as many many members here and on several facebook sites too i'm sure! the main thing would be to make a mold off of a perfect pair with the upper edges still intact, then if there are any cracks they would need to be smoothed and reworked in the final molds, so you have a clean new replicas of them with the metal molded in just like original
Posted By: TV 2M8O
Date Posted: 08-April-2018 at 10:30PM
Greg, put me down for a set as well.... if they are as John noted above.
Posted By: jversch
Date Posted: 09-April-2018 at 5:41AM
I would buy a set if they get made .
------------- Jerry VerSchneider 1972 Gran torino formal roof H Code 1973 Gran torino fast back H code.
Posted By: Timustbe
Date Posted: 22-April-2018 at 1:22PM
Add me to the list of those looking to get a set for my '72 Q Code Sport roof.
------------- Tim Northcutt '72 Ford Gran Torino Sport (Pearl White) '07 Jack Roush SC F-150 (red) '02 HD Road King Classic (Luxury Blue and Diamond Ice)
Posted By: bdaugette
Date Posted: 16-May-2018 at 10:31AM
I would also be interested..
------------- Bill Daugette 72 GTS 351C 4V
Posted By: Compton
Date Posted: 16-May-2018 at 1:12PM
Have been making a few enquiries with other rubber molding companies but they're all around NZ$2000 (US 1500) for the tooling of the mold...will be putting it on the back burner for a while as there's more important things to do on the car but will let you guys know when proceeding
Posted By: TV 2M8O
Date Posted: 17-May-2018 at 5:56AM
How much more for the steel inserts, the actual rubber and molding costs?? 20 sets presold for $100.00 or 30 set at $75.00 and tooling and material is covered?? I'm sure we could easily do that here on the forum.....
Posted By: Compton
Date Posted: 17-May-2018 at 1:38PM
Manufacturing costs are relatively cheap...about US$25-30 for the rubber injection part and probably around $10 maximum for the steel insert
Date Posted: 17-May-2018 at 3:13PM
if the final cost was $75-100 i think a lot could be sold!!! there's what 2k members here 2k on a fb site, 1.5k on another.... that many members most all of them need these seals!!! even if only 1/2 of all those guys bought them, that's a lot yes some wouldn't sell right away but if they were available and the word got out , they would sell!
Posted By: TV 2M8O
Date Posted: 18-May-2018 at 10:46AM
We here in the US will also have to figure the import duties/taxes. How much will those and shipping add to the cost?? Wonder if there is a US member with a business thru which a large lot of the seals could be imported and then shipped to members?
Hmmmm......
Posted By: TV 2M8O
Date Posted: 13-February-2019 at 5:15AM
LOOKY HERE.....
https://www.torino-pillar-seals.com/" rel="nofollow - https://www.torino-pillar-seals.com/
Posted By: 72FordGTS
Date Posted: 15-February-2019 at 4:16AM
TV 2M8O wrote:
LOOKY HERE.....<div id="UMS_TOOLTIP" style="left: -100000px; top: -100000px; cursor: pointer;">
Wow, someone is actually reproducing the seals - finally. Too bad they won't ship outside the lower 48 though. These guys claim to be restoring Torinos for almost 20 years, I wonder if they know about our site? Here's their story and a couple of pics:
<div id="UMS_TOOLTIP" style="left: -100000px; top: -100000px; cursor: pointer;">We are Gran Torino owners who have been searching for new pillar seals and body plugs to actually fit our car. We own a machine shop and thought why not expand and make a product that we could use on our 1976 Gran Torino, 2 door hardtop and our 1972 Gran Torino sport fastback. They had old deteriorating pillar seals and body seals. We couldn't find them anywhere.
We have been restoring Gran Torino's for seventeen years and we have never found a decent pair of pillar seals. Now with the introduction of 3D printing we decided to make them for ourselves and make them available to the rest of the Gran Torino owners. These are not restored seals. These are brand new 3D printed pillar seals. These should fit other 1972 Gran Torino sport fastbacks and 1974-1976 Gran Torino 2 door hardtops.
If there are any other impossible to find parts we would consider 3D printing or machining them if there is enough interest.
------------- Vince
Posted By: TV 2M8O
Date Posted: 15-February-2019 at 4:54AM
I asked them if the new pieces had the metal core, were UV resistant and how pliable they are. They state that there is NO metal core like the originals, they are NOT very flexible and are NOT UV resistant, but so far they are holding up in the Arizona climate.
Here are a few pics of my NOS passenger side seal for reference.....
Once my 'Mater is off to the body shop, I'll be ordering a set for mine!
Date Posted: 15-February-2019 at 12:32PM
interesting... i'm assuming they are a hard plastic?? which would eliminate the need for a metal backing, probably a polyethylene compound? oh btw joe... a while back you were thinking about 3d printing the std cluster rear housings, and you inquired about their chemical makeup?... i'm pretty sure those housings were made from poly vinyl chloride PVC
Date Posted: 15-February-2019 at 2:45PM
and we all know how well that turned out
Date Posted: 15-February-2019 at 4:59PM
what being made of PVC???? yeah UV and ozone does deteriorate it but the grey PVC they use for electrical conduit is UV resistant
Date Posted: 16-February-2019 at 8:38AM
You're probably right that it's plastic if it's 3D printed. I am not sure how well that'd work compared to rubber. It also doesn't look like the rear window on a fastback could roll down very well with that new design? At least someone is trying...
------------- Vince
Posted By: forddude
Date Posted: 22-February-2019 at 5:29AM
If any member ends up buying a pair, please let us all know your experience. Am sure we all would like to know the fit and quality.
Posted By: 7T9_Tbird
Date Posted: 22-February-2019 at 2:01PM
Key word is resistant. Even Sch 80 doesn't stand up to sunlight for too long without distorting. Look at a PVC run strapped horizontally against a wall in the sun for more than a year. Looks like the pipes on the wall at the rebel base on Hoth. And it expand and contracts quite a bit too.
------------- John 79 Thunderbird Heritage 79 Thunderbird Town Landau 02 Ram 1500 Sport Quad Cab
Date Posted: 24-April-2019 at 4:40AM
Vince, I am looking at ordering a set myself to see how they are. If you need, I can order a set for you and mail up via USPS.
Posted By: Regul8r 2
Date Posted: 24-April-2019 at 2:25PM
Jeff and I are in the process of getting these made CORRECTLY.
Supplies are on the way for us to start. they WILL have the metal insert and be of a flexible rubber OEM style material that do the job they were designed to do... KEEP WATER OUT OF THE QUARTERS
Plastic isn't going to do that.
------------- Carl, Member/Admin since 07. Still the same admin/moderator REGUL8R just needed a 2nd account for more picture space. Owner- www.CaNDeCustoms.com
Date Posted: 24-April-2019 at 2:54PM
Date Posted: 24-April-2019 at 11:45PM
Eliteman76 wrote:
Vince, I am looking at ordering a set myself to see how they are.If you need, I can order a set for you and mail up via USPS. |
Thanks for the offer Andy. I am going to hold off though, until someone reports back on if these are any good or not, especially if Carl is planning on getting some better quality ones made up.
------------- Vince
Posted By: rdtmto
Date Posted: 28-May-2019 at 5:53AM
We thought we would join the forum since we make the torino pillar seals. Just to let you know: we have changed the wording on our site. The pillar seals are made of PLA, Polyactic acid, not PVC. They are reasonably UV resistant and slightly flexible. We have had them on our torino's for two years in Arizona. We haven't had a problem with them as far as UV because they are behind closed doors. As far as flexibility: they don't need to flex, they fit right on the car. You can push them around a little to get a good fit. We have sold many pairs and the buyers are very happy with them. Thanks
------------- Barb K.
Date Posted: 28-May-2019 at 12:35PM
Thanks for posting more information on the latch pillar seals. Stick around the forum, there is lots of great people and info here.
------------- Vince
Posted By: 73GranTorinoSport
Date Posted: 28-May-2019 at 4:07PM
It's great to hear you are making the pillar seals. I am hoping you are referring to the "quarter window" seals pictured in the forum above. If yesI have been searching for a source of new pillar seals for years and I am interested in 2 sets for my 1972 and 1973 Gran Torino Sports. Can I get pricing information and pictures please? How can I find your website? Thanks. Danny L Haughn, Daytona Beach FL.
------------- 1972 Q-Code Gran Torino Sport 1973 Gran Torino Sport 1965 Mustang Coupe 2014 Mustang Convertible
Posted By: chris5769
Date Posted: 29-May-2019 at 2:24AM
I bought a set of the #d printed seals and am very happy with them thus far. I had to do a minor amount of trimming, but that was to be expected. They have just the right amount of flex to allow them to properly seat. Thanks Barb!!
------------- Cheers,
1975 Gran Torino
Posted By: TV 2M8O
Date Posted: 29-May-2019 at 3:30AM
Posted By: rdtmto
Date Posted: 30-May-2019 at 5:00AM
Thanks for the positive feedback Chris! The website is: http://www.torino-pillar-seals.com" rel="nofollow - www.torino-pillar-seals.com . We appreciate everyone who have installed them on their cars. Thanks everyone! Barb
Posted By: rdtmto
Date Posted: 30-June-2019 at 3:02PM
Please see our website at http://www.torino-pillar-seals.com" rel="nofollow - www.torino-pillar-seals.com to see the whole story behind the making of these seals. Thanks!
Posted By: rdtmto
Date Posted: 02-November-2020 at 3:51AM
We are very aware of this website. Actually we are members. We continue to make the pillar seals and we do ship to any state, including Hawaii and Alaska. It does cost a bit more for the buyer but we aim to please. Thanks, Pat and Barb
