pinto
Forum Name: General Automotive Technical Discussion
Forum Description: Technical Automotive discussion of anything not specific to mid-size Ford/Merc
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=14541
Printed Date: 19-April-2024 at 1:02PM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: pinto
Posted By: fordpower
Subject: pinto
Date Posted: 08-December-2015 at 3:04PM
Removed the fuel cell yesterday.It was full of water between steel shell and inner cell.Must have been condensation.Outer shell rusted through.Cell rusted to outer part.It was only setting 3yr.
Posted By: unlovedford
Date Posted: 09-December-2015 at 12:36AM
Sheesh. Sorry to hear that.
------------- Joe 1972 Mom's Squire Wagon 1972 Torino Wagon 1976 Torino 1968 Cougar XR7-First batch 1972 Torino 460 1989 BroncoII/Jeeps/Titanimous Popeye and Brutus (Rams)
Date Posted: 09-December-2015 at 12:47AM
Ya jazz said they sell the shell for 100. but how do you remove the inner its rusted right to the shell.
Date Posted: 13-December-2015 at 5:13AM
Posted By: californiajohnny
Date Posted: 13-December-2015 at 7:50AM
maybe i missed something here but, i thought pintos had a regular steel gas tank just like our torinos??? all the pintos i worked on many years ago appeared to have regular steel tanks
Posted By: Ranchero Fan
Date Posted: 13-December-2015 at 1:14PM
Safety thing. after the exploding gas tanks from rear end collision law suits?
------------- Brian 1973 Ford Ranchero Big Block. ''THE OTHER WOMAN''
Date Posted: 13-December-2015 at 1:15PM
Your are correct.The guy I bought it from installed a jazz fuel cell.It rusted out due to moisture between cell and shell.I just wonder if I replace it with a alm.one would same thing happen.
Date Posted: 13-December-2015 at 1:33PM
if i'm understanding this correctly, you have a plastic fuel cell inside the metal tank, if it's sealed for the gas, can't you drill a small 1/4" hole or two in the metal tank to let moisture drain out???(before you put in a new cell)
Posted By: smhj
Date Posted: 13-December-2015 at 9:40PM
A few were made out of Aluminum at work with no issues.
------------- 73MONTEGO
Date Posted: 14-December-2015 at 12:19AM
Do the alm ones have the inner cell or just foam .hole idea passed my mind.
Date Posted: 19-December-2015 at 11:04AM
cut out the rear end,now to find someone to help remove it.Then I can clean it up and put the 3.23 in it.Still have not found a shop near by that can change the axle to 5 by 4.5
Date Posted: 19-December-2015 at 2:18PM
many years ago i had my 4 lug monza axles redrilled to 5 lug they did an excellent job! cleaned and retrued all the surfaces, shipped them back in like a week! just make sure you specify stock lug studs or you'll get those 4" long racing studs
http://www.moserengineering.com/moser/shop-services/" rel="nofollow - http://www.moserengineering.com/moser/shop-services/
Date Posted: 19-December-2015 at 11:34PM
Thanks for the tip.Will try after Christmas.
Date Posted: 12-January-2016 at 1:06PM
Ready to put the cowl back on.There are 32 spot welds along the window area.should I glue it or attempt to weld it again.I am not a pro. welder.My concern is structure.
Date Posted: 12-January-2016 at 4:47PM
did you only drill the outer cowl piece regarding the spot welds? i'd weld it back in the spot weld hole, that's often referred to as "plug welding"
Date Posted: 20-January-2016 at 1:21AM
Welded cowl on. Non gas wire feed is splatter crazy. Welds look bad .Does it matter which direction you go.For word or back words.
Date Posted: 20-January-2016 at 2:34AM
i do both, just depends on what i'm welding
Date Posted: 20-January-2016 at 9:10AM
Next question anyone know were to find body measurements for body panels. I am replacing right inner fender,on unabody (sp)car it should have been part of sub frame.What I want is distance between fenders and some cross measurement from one side to other.
Date Posted: 22-February-2016 at 5:38AM
Is it better to bondo to clean metal or primer?
Posted By: dave302
Date Posted: 22-February-2016 at 8:39AM
It is better to put bondo over clean metal, not primer.
Posted By: Big Bird
Date Posted: 22-February-2016 at 9:05AM
Clean metal, but it can be used over epoxy primers (DP-90, etc.)
Date Posted: 22-February-2016 at 9:16AM
Thanks,soon as I buy a new grinder will get at it.
Date Posted: 22-February-2016 at 3:27PM
80 grit on a DA sander is fine you don't have to use a grinder unless to remove rust, 80 grit is enough "tooth" for the bondo to adhere to
Posted By: dave302
Date Posted: 22-February-2016 at 3:46PM
There are some rims for sale for a good price, but they most likely have a 5x4.75 bolt pattern. Maybe you can have the bolt pattern drilled to a 5x4.50 bolt pattern. If you want to see them https://newjersey.craigslist.org/wto/5442465508.html" rel="nofollow - Click here.
Date Posted: 29-February-2016 at 5:54AM
Needed front parking-turn sig.lens for 77pinto.
Posted By: dave302
Date Posted: 29-February-2016 at 10:48AM
Do you need just the front left and right turn signal lenses like number 1 in the picture below? Or do you also need the side parking lights, like number 2 in the picture below? If you want to see a front left turn signal lens for sale http://www.ebay.com/itm/FORD-PINTO-1977-lens-left-hand-/151641846665?hash=item234e8ef389:g:0mkAAOSwstxVIqUk" rel="nofollow - Click here.
Posted By: dave302
Date Posted: 29-February-2016 at 10:49AM
There is a side parking light lens for sale, but the seller did not say if it will fit a 1977 model. If you want to see it http://www.ebay.com/itm/NOS-FORD-PINTO-SIDE-marker-/151641858545?hash=item234e8f21f1:g:rvEAAOSwEeFVIqfW" rel="nofollow - Click here.
Date Posted: 29-February-2016 at 2:12PM
IIRC those front turn lenses are 76-77 specific. which side do you need? or both?
Posted By: dave302
Date Posted: 29-February-2016 at 3:36PM
The 77 and 78 front turn signal lenses appear to be exactly the same. The 76 appears to be different. There is a picture below of a 76 lens.There is a picture below of a 77 lens. There is a picture below of a 78 lens.
Date Posted: 29-February-2016 at 6:04PM
dave you might be right, it's been 20 years since i worked on pintos, but i remember those being a two year only thing
Date Posted: 29-February-2016 at 11:08PM
Need just the fronts,mine are cracked and missing piece. I am going to do away with side ones.
Posted By: Big Bird
Date Posted: 01-March-2016 at 9:03AM
There you go, making me want a pinto...
Date Posted: 01-March-2016 at 1:23PM
Ya I am going to have to try posting pic someday.
Posted By: dave302
Date Posted: 01-March-2016 at 11:44PM
If you want to see a car being parted out https://louisville.craigslist.org/pts/5429969923.html" rel="nofollow - Click here. If you want to see another car being parted out https://elpaso.craigslist.org/pts/5416126192.html" rel="nofollow - Click here.
Posted By: dave302
Date Posted: 01-March-2016 at 11:47PM
This next seller says that he has some parts for sale, but you will have to contact him to ask him if he has the lenses for sale. If you want to see it https://louisville.craigslist.org/pts/5428689021.html" rel="nofollow - Click here.
Date Posted: 02-March-2016 at 12:17AM
Posted By: dave302
Date Posted: 02-March-2016 at 12:48AM
Date Posted: 02-March-2016 at 1:26AM
There is a NICE Pinto for sale here locally. Has 10 hole GT wheels, maroon, LDO interior. I am soooo tempted, but have withstood it so far.
Date Posted: 02-March-2016 at 3:14AM
You need to post it so I can feel bad. What is the price?
Date Posted: 02-March-2016 at 4:15AM
$3,000 or best offer. Nice cloth original seats, nice interior period, clean under the hood, has the original wheels as well. A late model 305 hp Ford V6 would be ideal in this car.
Last year of production.
Date Posted: 02-March-2016 at 4:48AM
Ya 79 I believe. On the fox body I think.
Date Posted: 02-March-2016 at 11:30AM
'80 i think? yeah a 4.0 from a ranger would be sweet in a pinto let me know if you find some, because there are several pintos up at that yard near me, i can check, if the stupid weather is ever decent on the weekends...nice all week then Saturday comes...it's raining sideways!!!
Date Posted: 02-March-2016 at 1:30PM
I'll keep you in mind. Thanks
Posted By: dave302
Date Posted: 03-March-2016 at 1:49AM
unlovedford wrote:
Last year of production. |
fordpower wrote:
Ya 79 I believe. |
californiajohnny wrote:
'80 i think? | 1980 was the last year of the Pinto.
Date Posted: 03-March-2016 at 2:37AM
The world has gone to far.Called on lenses in TX.Guy wanted to send pic to my phone I am not that high tec. gave my email to send they he had no idea how to do that.
Date Posted: 03-March-2016 at 3:56AM
Yep, it is a 1980 model. I really like that little car.
Bob, there are no JY anywhere that still have older vehicles. Everyone crushed them all when scrap reached $15/100# last year. I would say to scour Search Tempest online to see if anyone has Pinto parts. Unfortunately, these were 2 years only, and most were hit in the front or are long-gone.
Date Posted: 03-March-2016 at 6:41AM
Bob, I don't know if you're a member there, look here, http://www.fordpinto.com" rel="nofollow - www.fordpinto.com in their classified section. Maybe someone has one, or give you a lead on one. Sorry, that's all I got. I checked Craigslist by me, and nothing in the Chg/NW Ind. area
Date Posted: 03-March-2016 at 6:56AM
Ya I belong,nothing like our site.
Date Posted: 03-March-2016 at 7:02AM
fordpower wrote:
Ya I belong,nothing like our site. |
I bet. I'll keep looking for you.
Posted By: dave302
Date Posted: 04-March-2016 at 8:55AM
This next seller did not advertise the turn signal lenses for sale, but he advertises if you are looking for any other parts just ask him. If you want to see it https://greenbay.craigslist.org/pts/5458087916.html" rel="nofollow - Click here. There is another one being parted, he has a few boxes of parts for sale. I cannot see if he has the lenses in the boxes, but you can contact him to ask him. If you want to see it http://grandrapids.craigslist.org/cto/5448115930.html" rel="nofollow - Click here.
Date Posted: 05-March-2016 at 12:51AM
called no. no response at this time
Date Posted: 16-March-2016 at 8:35AM
I found what appears to be inner fenders for my pinto.For the life of me can't see were they go.
Date Posted: 08-May-2016 at 6:13AM
Does anybody know a safe way to depressurize the bumper pistons want to tuck the pinto bumpers.
Posted By: Big Bird
Date Posted: 08-May-2016 at 7:41AM
Are they pressurized or just friction energy absorbers? Ford used both at different times.
Date Posted: 08-May-2016 at 8:38AM
IIRC the one's on my monza were oil filled so i drilled a small 1/8" hole at the rear on the side to drain the oil out, they may have a spring in side????IDK or friction type like randy stated??
Date Posted: 08-May-2016 at 1:57PM
Guess I'll try the hole idea.Watched utube I would have though drill hole in large cyl. They drilled in smaller one?
Date Posted: 10-May-2016 at 10:07AM
Drilled 1/2 deep hole nothing. Got out my joe tool and cut it off.It is a 2 in solid pipe.
Date Posted: 10-May-2016 at 1:40PM
there ya go, cut measure and weld
Date Posted: 11-May-2016 at 12:59AM
Must be a spring type still would like to remove it.Guess I will have to take it off car and play on vice.
Date Posted: 28-January-2017 at 5:13AM
Does anyone know which mustang motor mount is for the right side and left. I cleaned and painted last yr. don't remember which is which. Have to reverse for pinto.
