cam
Forum Name: Small Block Forum
Forum Description: 221, 255, 260, 302 and 351W engines
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=14543
Printed Date: 19-April-2024 at 1:55AM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: cam
Posted By: fordpower
Subject: cam
Date Posted: 09-December-2015 at 4:26AM
Just called crane cam to find out what this car had.The spc. are 484 lift 216 duration 110 separation.So for those of us that know little what does this mean.
Date Posted: 09-December-2015 at 5:29AM
I just looked it up at sumett act.is 216 both adv. is more like 274 ,why the difference.,
Posted By: Big Bird
Date Posted: 09-December-2015 at 12:19PM
Duration at .050 lift as opposed to total duration?
Date Posted: 09-December-2015 at 2:11PM
Ok thank. Guess I'll put it back in the motor.
Posted By: dave302
Date Posted: 09-December-2015 at 5:13PM
That appears to be a crane 13005 cam that you have there. I will post the specs. below so that the other members can see it. Cam Style: Hydraulic flat tappet Basic Operating RPM Range: 1,600-5,200 Intake Duration at 050 inch Lift: 216 Exhaust Duration at 050 inch Lift: 216 Advertised Intake Duration: 272 Advertised Exhaust Duration: 272 Intake Valve Lift with Factory Rocker Arm Ratio: 0.484 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.484 in. Lobe Separation (degrees): 110 Computer-Controlled Compatible: NoGrind Number: 272 H10
Date Posted: 11-December-2015 at 1:08AM
according to sumett this is the highest cam for a stock 9.1 or higher 302 with stock converter.Also rec 3.5 or higher gears? I was running 2.75 with aod.?Going to 3.23 from Joe.
Posted By: Big Bird
Date Posted: 11-December-2015 at 1:55PM
With my Crown Vics (80s square panthers), I was MUCH happier with 3.55 rear gears and the AOD than the factory 2.73. Swapped in a 3.27 axle out of necessity which wasn't quite as much fun, but still WAY better than factory.
Date Posted: 11-December-2015 at 2:28PM
It appears the problem not much made for 8in rear. Jegs has 7.5 8.8 and 9 but no 8.
