Dried interior plastic repair?
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=16768
Printed Date: 29-March-2024 at 12:03AM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Dried interior plastic repair?
Posted By: Power Surge
Subject: Dried interior plastic repair?
Date Posted: 01-January-2018 at 8:48AM
Has anyone come up with a good fix for plastic interior parts - like sport door panels, kick panels, and sail panels - that get gouges in the top layer of plastic over time? Any way to fill those area in before refinishing the panel?
------------- Sal Mennella 73 GTS 351 CJ 75 Cougar XR7 73 Ranchero - 5.0 Coyote swap - in progress Past Torinos - 72 Gran Torino, 75 Gran Torino, 75 Elite
Posted By: 72FordGTS
Date Posted: 02-January-2018 at 2:35PM
Sal, if you figure something out for this, please share it. Short of having them redone by JustDashes, which would cost a small fortune, I don't know of any other way.
------------- Vince
Date Posted: 02-January-2018 at 2:47PM
72FordGTS wrote:
Sal, if you figure something out for this, please share it. Short of having them redone by JustDashes, which would cost a small fortune, I don't know of any other way. |
Actually I may have found something! Well, my brother may have to be honest, lol. He talked to his local paint and restoration supplier today, and the guy said that SEM actually makes a texture spray. So you sand the part down, fill in the big gouges, and then spray the part with the texture spray. Then you shoot your color. He said if done right, it looks completely original.
Posted By: MrSmog
Date Posted: 02-January-2018 at 6:14PM
another idea i had on this very subject is could you sand off the loose degraded plastic, build back up with some sort of plastic epoxy and then lay a grained textured material over the top as it cures. when it dries you simply peel it up and leave the grained texture. They used to have a cheesy vinyl repair kit sold on tv years ago that was similar to this concept, but with time this should have improved greatly. I made a mold of the non skid pattern in a classic boston whalers floor and would use it as a pattern when i did gel/glass repairs in the non skid areas of whalers. when done right it was all but impossible to see the repaired area.
Posted By: Rockatansky
Date Posted: 03-January-2018 at 7:56AM
https://www.semproducts.com/product/plastic-adhesion-promoter/promoter" rel="nofollow - https://www.semproducts.com/product/texture-coating/39853" rel="nofollow -
Date Posted: 06-January-2018 at 3:13AM
Hmm, this seems like a good idea. Sal if you end up trying this can you take pictures and post them here?
------------- Vince
Date Posted: 06-January-2018 at 3:44AM
72FordGTS wrote:
Hmm, this seems like a good idea. Sal if you end up trying this can you take pictures and post them here? |
Yep, definitely. I might try the process on my interior sail panels first to see how it comes out. But I've been talking to some friends over on the Mustang II page who've done it, and they say it works awesome if you do it right.
Posted By: MrSmog
Date Posted: 06-January-2018 at 3:53AM
Power Surge wrote:
Yep, definitely. I might try the process on my interior sail panels first to see how it comes out. But I've been talking to some friends over on the Mustang II page who've done it, and they say it works awesome if you do it right. |
I imagine it couldn't be a spot repair but you'd have to do the whole panel since the grain would be different then the faux leather grain the factory stuff has. Would look much better then the dried, scratched uv damaged plastic for sure.
Date Posted: 06-January-2018 at 4:20AM
SEM also sells a 6 pack of square grain swatches, in 6 different popular patterns. So if you had a piece that you wanted to try to repair instead of redo completely, that would make it easy to reproduce the pattern. I'm going to get that as well, to play with a bit.
Posted By: MrSmog
Date Posted: 06-January-2018 at 12:17PM
Power Surge wrote:
SEM also sells a 6 pack of square grain swatches, in 6 different popular patterns. So if you had a piece that you wanted to try to repair instead of redo completely, that would make it easy to reproduce the pattern. I'm going to get that as well, to play with a bit. |
didn't know they had that. I have used sem stuff a few times, always happy with the results.
