a few electronics questions
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=16842
Printed Date: 19-April-2024 at 4:04AM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: a few electronics questions
Posted By: tom72torino
Subject: a few electronics questions
Date Posted: 06-February-2018 at 11:45PM
Hi Guys! I'm just changing my turn signal switch. How do I get this steering column shroud of? It looks like this:
...and consists of 2 parts, but without screws. That means they have to be clipped somehow.
I'm also looking for the right turn signal switch for my 72 gran torino. Mounted in my car behind a standard 2 spoke steering wheel is this one:
This would, however, according to my research of a 71er be. I have only ever found the one for the 72 model with this layout here:
Which is the right one now?
One more question about the horn. Currently only one horn is installed and I want to switch to a 2-tone horn. One for high pitch and one for low pitch. I could not find any relay. Is no relay installed in the 72er? Can I just switch to 2 horns without an relay? My rim blow button for the horn does not work properly and the original part is too expensive for me. Therefore, I want to install a small switch behind the steering wheel pad on the left and right of the 2-spoke steering wheel pad. How many amps does a horn draw normally or 2 horns? So that I can get a suitable switch, which is sufficiently dimensioned. Is a 3 amps switch sufficient?
Thanks a lot for your help! Best greetings from over the big pond from Austria! Thomas
------------- Have a nice day! Greetings from austria! Thomas
Posted By: californiajohnny
Date Posted: 07-February-2018 at 6:00PM
the plastic collar has 2 screws and it clips together but there are 2 plastic pegs on the end that slide off...one section slides off of the other. go easy and slow the pegs get messed up easy
the switch in the rock auto pic looks correct
the horns on these cars don't use a relay, they have positive power in and positive power out. as far as duel horns there's a jumper wire that feeds both horns, it plugs into your single horn wire at the horn btw i have that wire
Date Posted: 07-February-2018 at 7:21PM
There are no screws. I have already tried to slide off. Then I'll take a closer look at it again.
Although I'm still unsure, since this one of the 71er looks more like mine......
....but I will order the turn signal switch from the '72 and hope that it will work. So only a cable from the positive connection from the first horn to the positive connection of the second horn is placed? Great John, then I would be interested in the cable! Send you a pm.
Date Posted: 08-February-2018 at 3:26PM
yes if you have 1 horn, unplug the connector at the horn the jumper wire plugs into your wire, 1 connector on it plugs onto 1 horn, the other connector plugs onto the second horn got your PM
Posted By: AgentCooper
Date Posted: 11-February-2018 at 4:05PM
Mhh similar question here, I want to replace my signal turn, Gran Torino 75.... any idea where I can found which part works for me? The only tool that I have is search on ebay "gran torino 75 turn signal".... :S
------------- The owls are not what they seem
Date Posted: 11-February-2018 at 4:31PM
it should look like this...
this is a good pic showing the 2 copper pegs for the horn contact
Date Posted: 11-February-2018 at 4:33PM
Do you have one?
Date Posted: 11-February-2018 at 4:36PM
i should have 1 or 2?
