Print Page | Close Window
'76 Torino Resistor Wire
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=17031
Printed Date: 16-April-2024 at 8:48AM
Topic: '76 Torino Resistor Wire
Posted By: bkulibert
Subject: '76 Torino Resistor Wire
Date Posted: 22-April-2018 at 1:47PM
Where does the black resistor wire go that comes out of ignition wire plug go?  Does it connect to the resistor wire that comes out of the speedometer plug?
Posted By: californiajohnny
Date Posted: 22-April-2018 at 2:35PM
i don't remember it being black IIRC it's white w/red stripe or green w/red stripe? the ignition resistor wire?that lowers the voltage to the coil?
Date Posted: 22-April-2018 at 2:38PM
now there's a small voltage regulator on the back of the gauge cluster circuit board, but it's self contained to the circuit board, if that's what you're inquiring about?
Date Posted: 26-June-2018 at 8:15AM
this is a black wire coming out of the speedometer plug and one of the plugs for the ignition switch. it says "RESISTOR WIRE DO NOT CUT OR SPLICE" on it.
Posted By: Rockatansky
Date Posted: 26-June-2018 at 8:25AM
1st, is this a std cluster or GT gauges cluster with a tach?
and is the car believed to be factory stock original in regards to the dash & wiring harnesses?
have you seen this thread,
http://forum.grantorinosport.org/info-72-79-gauge-clusters-and-wiring_topic2933.html" rel="nofollow - http://forum.grantorinosport.org/info-72-79-gauge-clusters-and-wiring_topic2933.html
can you pick out a pic that shows what you have?
there's a pic on the 1st page that shows a wire as you've described
Posted By: andrewok1
Date Posted: 26-June-2018 at 9:05AM
GET IT GOT IT GONE !!!!!!!
Date Posted: 26-June-2018 at 9:15AM
