Hood Scoop Template
Forum Name: 1968-1969 Ford and Mercury
Forum Description: Technical discussion for 1968-1969 Ford and Mercury
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=18154
Printed Date: 19-April-2024 at 4:59AM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Hood Scoop Template
Posted By: piper62j
Subject: Hood Scoop Template
Date Posted: 06-July-2019 at 1:41AM
Does anyone have, or know how to obtain a template for the non functional hood scoop for the 68 - 69 Torinos? If that's not available, are there dimensions that can be used instead? I just picked up a complete OEM unit with lights and would like to install it on my 68. Thanks in advance..
Posted By: 72FordGTS
Date Posted: 06-July-2019 at 11:56AM
This one here looks correct: http://www.2040-parts.com/1968-1969-ford-torino-ranchero-functional-hood-scoop-template-428-cj-scj-bbf-i296116/" rel="nofollow - http://www.2040-parts.com/1968-1969-ford-torino-ranchero-functional-hood-scoop-template-428-cj-scj-bbf-i296116/
------------- Vince
Posted By: californiajohnny
Date Posted: 06-July-2019 at 1:55PM
that would probably work for non functional just don't cut out the 4 ovals
Posted By: hogfiddles
Date Posted: 06-July-2019 at 3:20PM
the 68-69 scoop is non-functional anyway, even with the holes cut out. I have saved the center section of my old scooped hood so I can trace the actual holes for you. Send me a private message to remind me as I am away from home for a week.
Dave Fox
------------- 1973 Gran Torino Sport - Q code “Q-Clone” project-on-hold 1972 Gran Torino Sport - Q code new project 1972 Gran Torino - parts 1969 Torino GT - M code 95+/- mid-80's Yamaha XJ-Series (10 trophies)
Posted By: piper62j
Date Posted: 10-July-2019 at 2:50AM
I believe I have found the correct template for this application. The seller does not indicate the vehicle type, but the template is a perfect match for my oem non functional scoop.. Purchased it and will update you on how things work out..
Date Posted: 19-July-2019 at 5:27AM
that just shows you the bolt holes and the turnsignal holes.... it does not show you the 4-hole oval. The oval is there regardless of whether it is a "functional" scoop or not.....
Posted By: piper62j
Date Posted: 19-July-2019 at 7:01AM
Hogfiddles.. You are correct. I was searching on line and actually saw the 4 large holes in the hood. I'm not going to cut those out. My hood is original and fits perfectly, so the mounting holes and small bulb access holes will do for now.. Thanks for the update.. Good catch..
Date Posted: 20-July-2019 at 3:15PM
ok, cool. If you do decide to make the rest of the cutouts, let me know. I saved the center of my old hood, so I can always trace the EXACT shapes
