Rear Link Assembly Bushing
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=18162
Printed Date: 23-April-2024 at 2:17AM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Rear Link Assembly Bushing
Posted By: texanrebel
Subject: Rear Link Assembly Bushing
Date Posted: 11-July-2019 at 12:08AM
I believe I read on here that there are no bushings being reproduced for the rear link assembly Part # D20Z-5K484 on 1972-73 Montego's and Torino's? ...I have attached a diagram circling what I have not been able to find
Bushings - 5C492 Washers - 18041
Just curious if anyone has sourced these recently, thanks. uploads/5585/End_Link_Assembly_Bushings.pdf" rel="nofollow - uploads/5585/End_Link_Assembly_Bushings.pdf
------------- 1972 Montego GT 1977 Mercury Monarch 1988 Ford Thunderbird Turbo Coupe
Posted By: aquartlow
Date Posted: 11-July-2019 at 4:55AM
IMO, our intermediate upper front or upper rear shock bushings can be used "in a pinch" since there may be no original style bushings to be found. Have you tried your parts request on NOSParts.com or rearcounter.com, I have found NOS parts that I once thought to be non-existent any more. Hope this helps.
Posted By: Big Bird
Date Posted: 11-July-2019 at 10:27AM
I have regular bolts in my end links because the original bolts broke. Took bolts and put them thru the hole in the top of the U shaped shackle, ran a nut down and then used some front end links for parts to finish. There is a tube, another nut, a washer, a bushing, the hole in the frame bracket, another bushing, another washer, and then a nut and finally a jam nut. It's been there since 2003, and seems to work.
Posted By: 72FordGTS
Date Posted: 11-July-2019 at 1:05PM
As far as I know, these are not reproduced, so NOS (if you can find it) is your only choice. Do you have the originals by chance? You could always get some detailed measurements from them and maybe contact Energy suspension and see if they have something that would work. Randy, you should take a pic of your setup.
------------- Vince
Date Posted: 11-July-2019 at 2:12PM
Thanks everyone, I did look on NOS and Rearcounter but no luck so far. I do have the originals, they are still on. I removed the bar to replace the bushing pressed into the ends...so this weekend I will remove the originals and make measurements - Thanks Vince I'll post responses from Energy Suspension here.
Billy
Posted By: californiajohnny
Date Posted: 11-July-2019 at 3:05PM
these are what i used on my factory rear bar... they fit great
energysuspension 9-8141G Sway bar end bushing 9-8101G Upper end link bushing
Date Posted: 26-July-2019 at 11:04PM
Well no response from Energy Suspension. As you warned Randy, the bolts break easily and mine did, so I will be going your route by frankensteining some spare front end link parts. I offered to send my old rear link assembly, broken bolt and all including the bushings to Energy Suspension for them to copy. Mentioned I didn't even want credit, just the ability to purchase a new assembly. And crickets....
Since I am afraid to make this situation worse, can someone more versed in this advise the best way to remove the bolt / shaft from the fork so that I can run a new bolt through? Thanks
Posted By: russosborne
Date Posted: 27-July-2019 at 12:55AM
This is how someone rebuilt their's. Not sure if the bushings he used will work for you, but at least you can see how he did it. http://forum.grantorinosport.org/how-to-rebuild-rear-sway-bar-links_topic14373.html" rel="nofollow - http://forum.grantorinosport.org/how-to-rebuild-rear-sway-bar-links_topic14373.html Russ
Date Posted: 27-July-2019 at 2:45AM
Excellent, kinda what I was thinking...I'm not much of a welder so I'll probably just go the lock nut route. Appreciate the link!
Date Posted: 27-July-2019 at 4:50AM
you wouldn't have to weld that sleeve on as joe did, just the carriage bolt, proper length sleeve and poly lock nut
