Newbe
Category: General Discussion
Forum Name: The Welcome Mat
Forum Description: New members, please post here and introduce yourselves
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=18636
Printed Date: 18-April-2024 at 9:46PM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Newbe
Posted By: Jedi
Subject: Newbe
Date Posted: 12-February-2020 at 1:08PM
Hi Forum Members,
My name is Jim and I hail from British Columbia, Canada
Currently working on a 1970 Mercury Cyclone Spoiler 429CJ
Hope to gain some members knowledge on these cars
Cheers Jim
Posted By: californiajohnny
Date Posted: 12-February-2020 at 1:47PM
welcome jim! post some pics when you get upgraded
Posted By: 72FordGTS
Date Posted: 12-February-2020 at 1:55PM
Welcome aboard Jim! I have upgraded you so you have full privileges and can post pictures. We'd love to see that Cyclone it sounds great.
------------- Vince
Posted By: handsofstone
Date Posted: 12-February-2020 at 5:36PM
Posted By: Jedi
Date Posted: 12-February-2020 at 5:46PM
I tried several times but no luck
Jim
Date Posted: 12-February-2020 at 6:43PM
did you view "how to post pics"? view the tutorial video i did there... thats for uploading from a computer but from a phone is similar
Posted By: Jedi
Date Posted: 12-February-2020 at 6:58PM
Tried a few times with no luck, I did read through again
Jim
Posted By: kychevyguy
Date Posted: 12-February-2020 at 11:55PM
Welcome to the forum.
------------- JT, USAF Ret./Architect 1971 Ford F100 "Lizzy" 1971 Cougar XR7 "Kitty" 1984 Chevy Silverado "Sylvia" 2009 Smart Fortwo Cabrio "Lil Dude" 2015 Volvo XC60 R-Design "Sven"
Date Posted: 13-February-2020 at 5:00AM
If you leave this box in reply, it won't work.Also, turn off screen rotation if on a droid phone.
Posted By: Jedi
Date Posted: 13-February-2020 at 5:25AM
Thanks, but I don’t have that little box
Posted By: Jedi
Date Posted: 13-February-2020 at 5:28AM
I’m getting a preview picture, but still can’t post
Jim
Date Posted: 13-February-2020 at 6:37AM
Below the oreview are you clicking OK? Once you do that then you should be able to post reply. It took me a while to figure it out.
Posted By: JackC
Date Posted: 13-February-2020 at 12:26PM
Date Posted: 13-February-2020 at 3:34PM
if you're seeing it but it don't post you must be missing a step???
Posted By: Jedi
Date Posted: 13-February-2020 at 3:41PM
I agree, maybe something to do with size
Date Posted: 14-February-2020 at 9:56AM
You uploaded the photo fine, I added it to your post. Nice Cyclone!
Try watching the tutorial video we have in the how to post photos thread. If you see the preview of the photo, all you should have to do is click ok and it should post in the text box.
------------- Vince
Date Posted: 14-February-2020 at 1:28PM
Posted By: Steve M.
Date Posted: 15-February-2020 at 12:43AM
Very nice. Not too many left.
------------- Steve M.
Posted By: Jedi
Date Posted: 16-February-2020 at 9:49AM
Hi Forum Members,
just came back on the site and see that my picture finally posted.
Story on the car is it belongs to my Uncle from Vancouver, he bought the car brand new but it hasn’t been driven since 1989.
I told him if he wanted I would come down from where I live pick the car up and bring it home. I’ve been puttering away on it for a couple of months and hopefully I might have it running this week.
Cheers Jim
Date Posted: 16-February-2020 at 10:27AM
Make sure it manually turns over. That is a long time for exposed cylinder walls to be sitting without protection. Cracking a piston would suck.
Posted By: Jedi
Date Posted: 16-February-2020 at 10:31AM
I’ve had the heads off and rebuilt, the engine turns over quite nicely, I also installed new timing chain and gears
For sure I’ll have my fingers crossed
Date Posted: 16-February-2020 at 3:46PM
Excellent. Keep on keepin on.
Posted By: Jedi
Date Posted: 20-February-2020 at 4:39PM
Udate
I got the 429 CJ running today, started right up but wouldn’t idle down, I think a little adjustment on the carburetor will help, sounded great and had good oil pressure.
I’ve got a small coolant leak on the water pump, hopefully not a real big fix, I dread the thoughts of having to pull the timing chain cover to fix this problem as the water pump is bolted to it.
Overall quite happy with my progress for a car that hasn’t run in thirty years
Jim
Date Posted: 20-February-2020 at 5:00PM
Why would you have to pull the timing chain cobec?
Posted By: Jedi
Date Posted: 20-February-2020 at 5:29PM
Apparently the aluminum timing chain covers can get corrosion on them and the water pump bolts to the cover. Hence the coolant leak is actually caused by the timing chain cover and not the water pump itself
Date Posted: 21-February-2020 at 12:08AM
Makes sense. Fingers crossed for ya.
Date Posted: 21-February-2020 at 11:17AM
if you try to tighten or loosen the bolts and it don't feel right stop! sometimes the long bolts through the aluminum cover rust and corrode if any are you can heat the bolt up and burn out some corrosion so you don't snap a bolt off
Posted By: Jedi
Date Posted: 21-February-2020 at 1:51PM
Hi There,
I got some things sorted out today, engine runs good with no coolant leaks, super throttle response.
It’s currently idling at about 1000 RPM, part of the problem is I have the timing set at about 20 BFTDC. Tomorrow I’ll bring the timing back to 10 degrees and check the PCV, hopefully I can get the idle down to about 700 RPM
Starting to get excited about getting this old Cyclone out for a drive, hopefully in the next week or so
Cheers Jim
Posted By: Jedi
Date Posted: 28-February-2020 at 1:16PM
Update,
I took the Cyclone out for a shakedown cruise today, it ran pretty well with no issues, well except for one.
It’s pretty loud though, I’ve ordered a new set of Proflow mufflers for it, should be here next week, right now it has an old set of burned out mufflers with no tailpipes.
I guess the one small issue is the horn doesn’t work, it has one of those horn rings that you squeeze with your thumbs on the inside edge of the wheel itself. That can be a next winter project, maybe someone can chime in if they know anything about this type of horn button.
Cheers Jim
Date Posted: 29-February-2020 at 1:59AM
Most likely the horn itself is the problem. Check the fuse then unplug the wire from the horn and hook it to a test light.
Date Posted: 29-February-2020 at 2:00AM
Is the steering wheel cracked?
Posted By: Jedi
Date Posted: 29-February-2020 at 4:23AM
Will do, just having coffee, I’ll check that out when I get home
Thanks Jim
Posted By: Jedi
Date Posted: 01-March-2020 at 8:54AM
The wheel does have some separation where the spoke joins the wheel, I suspect it probably doesn’t work. I have no power at the horns, didn’t check fuses, the horns don’t work as well. I ran power to the horns from the battery, with no results.
I’ll worry about another time.
Jim
