INFO: 1972 - 1979 Body Insulator Bushings
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=2935
Printed Date: 22-April-2024 at 6:29PM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: INFO: 1972 - 1979 Body Insulator Bushings
Posted By: Psquare75
Subject: INFO: 1972 - 1979 Body Insulator Bushings
Date Posted: 04-January-2010 at 4:51PM
Taken from Ranchero.us with permission of 72GTVA
Attached are some diagrams for Body Mounts: If we find a source for bushings correctly sized we'll post that information too:
Note: Sometime between '73 and '75 the #4 body mount was eliminated and, the #5 mount on the 77-79 models is not a bolt in unit like the 72-76 models. The frame does not have an access for the hardware. They use a press in type rubber mount that sits on the frame and the body just lays on that (no hardware).
If you have any updated measurements or information send me a note and we'll include it with this Reference Note.
------------- Paul 77 XR7 460/C6/3.00:1 *SOLD* 78 XR7 523/C6/3.5:1 79 F100 460/TKO500/3.25:1 'I also have some left over potatoes-I understand you can generate electricity from them'- Foote500
Posted By: smitty-1976
Date Posted: 06-January-2010 at 7:14AM
Energy Suspension has a universal Body Mount that I used on my '76. Look under universal products. I am going off memory but i believe the number is 9.4102.
http://www.energysuspension.com/universal-products/link-flange-type-bushings-universal-mounts-isolators.html - http://www.energysuspension.com/universal-products/link-flange-type-bushings-universal-mounts-isolators.html
Posted By: Eliteman76
Date Posted: 11-March-2010 at 4:10PM
Hey, just a little tidbit I wanted to also pass along. Late model crown vic body mounts are identical to the original Torino units.
------------- Andrew:GTS.ORG admin, '72 Q code 5 speed Restomod Pondering: #99Problems
Posted By: Regul8r
Date Posted: 11-March-2010 at 4:18PM
tell me more Andy!!!!
------------- Carl Corey (Moderator/Event Coordinator) Contact ANYTIME! 1976 Ford Elite "Lola Mae" 97 Suzuki Intruder 1400 US Army Retired
Date Posted: 11-March-2010 at 4:43PM
While I was out at the yard pulling the tbird/CV seats and wandering around, there was a police cruiser I want to say 2000-2002 in the yard, and it was missing a 1/4. Went over and the body bushings were easy enough to get at, and the thing looked about identical to the Torino. Pulling it out of the frame, they have the same little bump that my originals had, for alignment in the frame. I didn't see the lower body bushing, but it's something worth taking a look at.
Posted By: 73GTS
Date Posted: 22-March-2010 at 1:50AM
For those who missed this post.......
http://forum.grantorinosport.org/body-mounts_topic2166_post18426.html?KW=body+mounts#18426 - http://forum.grantorinosport.org/body-mounts_topic2166_post18426.html?KW=body+mounts#18426
73GTS
Joined: 22-September-2008 Location: Cleveland, Ohio Online Status: Offline Posts: 204 |
http://forum.grantorinosport.org/new_reply_form.asp?M=Q&PID=18428&PN=1&TR=6 - Quote http://forum.grantorinosport.org/new_reply_form.asp?PID=18428&PN=1&TR=6 - Reply http://forum.grantorinosport.org/forum_posts.asp?TID=2691&PID=18428&title=72-torino-radiator-core-support-rubbers#18428"> Posted: 18-November-2009 at 6:18PM |
I didn't know which post to post this to, so I'm pasteing to all that apply.
"Originally posted by rab1969
AFTER MORE RESEARCH AND A $20.00 CHANCE I HAVE FOUND THAT 2008 FORD CROWN VICTORIA BODY MOUNTS AND RADIATOR SUPPORT MOUNTS ARE THE EXACT SAME MOUNTS. I JACKED THE BODY UP AND REMOVED AN OLD MOUNT AND REPLACED IT WITH THE NEW ONE AND LOWERD THE BODY BACK DOWN . AND IT WAS A PERFECT MATCH. WITH NO MODIFACTIONS WHAT SO EVER ALL YOU HAVE TO DO IS REPLACE THE BOLT THAT COMES WITH THE MOUNTS WITH THE ORGINAL ONE OR REPLACE THE BOLT WITH A NEW ONE. THE PART NO. ARE (UPPER MOUNT)6W1Z-5400396-A AND (LOWER) 6W1Z-5C155-AA. YOU CAN ORDER THESE PARTS WHOLESALE THRU BOB UTTER FORD OUT OF TEXAS. GOOD LUCK WITH YOUR PROJECT." |
____________________________
I just purchased 1 of these mounts to see if in fact it would work. Here's what I came up with. Keep in mind my body is on a rotisserie and my frame is on a cart on it's side so it made it pretty easy to check every mounting area out.
Upper mount - only difference is it's about 1/8"-1/4" taller [not too big of a deal] Other than that it's a perfect fit. (10 mounts)
Lower mount - The size is perfect, but where it contacts the frame it's cone shaped as if it would wedge into a hole. (not flat like original) Not too sure if this is a problem. Also, when tight, I can turn the mount in the frame by hand. But it is pretty snug, just not very tight.
Bolt - I do not recommend re-using the original bolt. It won't be long enough. Need new bolts.
Radiator core support - These mounts will not work for this. I haven't figured out yet what will work. I'm still working on this.
As a side note; there are other size mounts on this car along with some sort of rad core support mount. I will check out.
These mounts are for 2003 - 2009 Ford Crown Victoria's with a 2006 part number.
Jim
1970 429 CJ J code Convertible 1 of 37 1973 Gran Torino Sport original Q code W/ '70 429 CJ C6 3000 stall & 4:30 Locker |
------------- Jim
Posted By: Regul8r
Date Posted: 22-March-2010 at 10:48AM
NOW... I am confuzzled!
Are they in fact the same or are they in fact different but will work?
IF they are not identical and will work... what will the difference do?
Posted By: 73GTS
Date Posted: 22-March-2010 at 1:03PM
Email me for info I just lost all I tried to post "ACCESS DENIED"
------------- Jim
Posted By: 73GTS
Date Posted: 26-March-2010 at 4:01AM
OK I'll try it again,
These CV mounts are about as close as you will come without modifying. The differences are minor and I don't consider to be too big a deal. You just need new bolts and the radiator core support mounts. I am going to use a combination of old core support mounts and new. New consisting of possibly 73 truck core support mounts I bought and the universal mounts I bought from Energy Suspensions. This should work fine. I should be able to get it done without too many problems.
------------- Jim
Posted By: rrlcommish
Date Posted: 26-March-2010 at 8:32AM
Where do you get new bolts?
------------- 1972 Gran Torino Sport Fastback, Bored 30-over 351C - 4V, Lt Blue, Pertronix Ignitor, dual exhaust with Turbo mufflers, otherwise stock
Posted By: 73GTS
Date Posted: 26-March-2010 at 12:20PM
rrlcommish wrote:
Where do you get new bolts? |
You need a bolt that's a little longer. I'm going to measure the old bolts and mount and figure against the new mount and order them online. They are 8 grade and can be bought online easily.
------------- Jim
Date Posted: 26-March-2010 at 5:34PM
Keep in mind, the OEM bolts have a taper. Which may mean you will need to grind the tip to aid in putting the bolt in. I had a parts car with mint isolators that I used. I tried using new bolts identical in size, however due to them not being tapered, they were a PITA to try to use, so I dug through my collection of bolts cleaned the threads up, and reused what I had. I still have a couple boxes of Torino mounts.
Concerning the radiator support mounts, I have posted what I used 3 or 4 times. Ford LTD bushings, they were available for pretty reasonable from ford. What I used was Ford bushings meant for an LTD, I forget the year. My parts receipt shows: E2AZ*5400155*A ABSORBER List $7.75, net cost each was $6.43 each back in 2002. Damn, that's depressing...2002 is when I got them, and I still aint done almost 7 years later. Anyways:
Posted By: 73GTS
Date Posted: 27-March-2010 at 3:10AM
Andy, Is that a 2pc mount? Do you buy 2 or 4?
------------- Jim
Date Posted: 27-March-2010 at 2:47PM
I bought 4 of them. I also bought a couple plated body washers {shown in the picture with the red prybar} inserted into the top. Pretty much identical in size to originals, plus they are not rubber.
Posted By: 73GTS
Date Posted: 27-March-2010 at 4:39PM
What did you use inside the frame?
------------- Jim
Date Posted: 28-March-2010 at 5:27PM
you know what, I honestly am drawing a blank. I will try to take a peak tomorrow and see. I thought I only bought 4, but maybe thinking now I got 6.
Date Posted: 05-April-2010 at 2:24AM
I measured my bolts and they are 2 1/2" long, 1 1/2" thread, 7/16" coarse thread and 5/8" hex head. Anyone know how much longer of a bolt is needed? And where did you order the new bolts from?
Posted By: steve
Date Posted: 27-April-2010 at 11:40AM
Hello everyone ! I got the energy suspension kit for a chevelle ? I am not ready for them yet but will be before winter. Does anybody know a good inexpensive rear controll arm set up ?
Date Posted: 05-July-2010 at 9:20AM
Anyone actually USE ANYTHING from this sticky yet?
Posted By: steve
Date Posted: 05-July-2010 at 10:36AM
Yes !! I got quite alot from this thread. I may not be offering any records in rebuilding but I am moving fwd. I recently bought a 1971 429 thunder jet engine with the ( dove-c ) heads to build my 514 stroker from.
Posted By: occupant
Date Posted: 05-July-2010 at 11:06AM
Something we could do is build up a TECH ARCHIVE of the important, but not posted on often, threads that contain vital information. Stuff like the links to the 335 engine website, this body mount thread, etc etc. They can be copied over and made to be read-only or something and in their own forum. Or left in a single stickied thread up top. Then leave the original where it was for discussions about it, and have links to the discussion thread from the "tech archive" thread.
------------- 08 Uplander LS, 262K, broken again 08 Explorer EB, 195K, for the wife still looking for another something
Posted By: steve
Date Posted: 05-July-2010 at 11:33AM
wwhhooaa That sounds wwaayyy to confusing to this old dawg.
Posted By: occupant
Date Posted: 05-July-2010 at 1:02PM
What I'm saying is instead of having six stickied threads up top, have ONE stickied thread that contains links and titles for the important threads. The threads may move around and get hits or not, but when you're looking for tech advice or a how-to thread, you could check the ONE stickied topic at the top of the list to see, oh, hey there it is, body insulator bushings, click it, and go to that thread.
Date Posted: 07-July-2010 at 3:12AM
That's how Hotrodders.com is. I guess whatever the tribe wants (and Scott approves of).
My initial question is still open. Who has actually tried to use any of these body bushings?
Date Posted: 03-August-2010 at 5:52AM
Well...small update:
For those out there following my messed up, screwed up 9 year build, the bushings I bought from Ford, for the radiator support, I would now suggest an alternative.
I was working on my AC system last week, and while under the car I noticed the 5 year old bushings deformed from what I can assume is too much pressure or weight.
So much for getting a body bushing from Ford thinking yeah, that's the ticket!
Posted By: Regul8r
Date Posted: 03-August-2010 at 7:46AM
Show us what you mean Andy
Posted By: steve
Date Posted: 28-September-2010 at 2:29PM
Good thing that when I did my frame I left the rotted out rad mounts on it. Went thru sandblasting / POR / primmer / and undercoating. Everything from front to rear was removed except them. Left them because I was unsure ! Now I am putting new stuff and theyre still sitting there waiting ???
------------- 72 gts fst bk in 1982 !!
currently building 73 fast back with a dove-a 429.
Posted By: steve
Date Posted: 28-September-2010 at 2:34PM
Date Posted: 17-October-2010 at 2:36PM
OK, sorry for the delay, to outline what I did on just the radiator support. I finally found the pictures and actually got them grouped together.
So, here are the body bushings I located at a Ford dealer. I
stuck a body washer in the open end:
Using a new bolt identical to the original length:
This had some of the body spacers off my original support for this:
Last time I was under the car, I noticed this:
Needless to say, I am not happy. Need to check into other suggestions like the CV mounts. Another winter project I guess.
**edited posting as all the original links were broken. Here is the shot of the updated bushing I used, as described in the other thread:
Posted By: Ron Earp
Date Posted: 11-December-2010 at 11:12AM
Guys, maybe this thread needs splitting into radiator mounts and body mounts. Two completely different animals here.
With respect to a 72 GTS I'm interested in what to do about body mounts. My body is going back on the frame in about three weeks and I will need to solve this problem for sure. Unlike most of you it seems I do not have access to a salvage yard to walk around in and compare parts.
A couple of questions:
1) Does anyone have the body diagrams shown at the start of the thread with the thicknesses of the mounts? I can't seem to make out the thicknesses.
2) The Crown Vic body mounts - they work but in some places might be 1/8" to 1/4" too thick?
3) I understand the mounts that are between the frame and the body. What is inside the frame? When I removed my body what was inside the frame was so badly rotted I can't tell how thick they were nor what they really looked like.
------------- 04 Ford Lightning 72 GTS BB Stroker & Toploader 98 Mustang ITS SCCA #38 08 Buell Ulysses http://www.gt40s.com" rel="nofollow - GT40s.com
Posted By: 73GTS
Date Posted: 11-December-2010 at 11:38AM
All your questions should be answered here........ http://forum.grantorinosport.org/1972-1979-body-insulator-bushings-updateupdate_topic4285.html - http://forum.grantorinosport.org/1972-1979-body-insulator-bushings-updateupdate_topic4285.html
------------- Jim
Posted By: Ron Earp
Date Posted: 12-December-2010 at 12:40AM
Excellent Jim!
I have a question about your example and used your photo to assist. The thick blue line represents the top of the frame rail.
1) Do I have the basic idea correct?
2) Do I need the "top" washer, the one that would go between the body and the mount?
3) Is there enough access from the bottom to actually get the lower mount into the frame? I don't remember the holes being that large but I also don't know how big a round these pieces are.
Posted By: 73GTS
Date Posted: 12-December-2010 at 5:06AM
Ron Earp wrote:
Excellent Jim!
The nut and washer in RED is not used when mount is installed. I used it for illustration only. (Yellow) rubber mount will be between the frame and body. BLUE circle is the under frame mount. I have it in the rear location, but it will fit perfectly through all frame holes. BLUE line is the frame. If you look carefully at the mount in yellow circle, you can see the silver steel sleeve. That is what goes between the body and this mount.
------------- Jim
Date Posted: 12-December-2010 at 7:28AM
Hey Andy... IMO, you sure they aren't supposed to bulge like that OEM? If the height is correct and it doesn't move........ *shrug*
Date Posted: 13-December-2010 at 1:59PM
I don't know. One of my problems I am having...the front end of the front clip seems like it's move a hell of a lot.
Posted By: lynchster
Date Posted: 09-September-2011 at 5:31PM
If anyone is interested I decided to take a shot using 68-72 Chevelle body mount bushings. The size is a decent match. I didn't have to trim anything but I did have to prep 4 spares (?) that came with the kit so I had 10 matching ones. Should know all there is to know next weekend.Chuck
------------- Chuck 72 Gran Torino Sport 13 Taurus SHO "Mr Pig"
Posted By: torkair
Date Posted: 20-April-2012 at 5:42PM
I am in need of radiator core support bushings, the ones on my Ranchero are totally trashed. Any recomendations?
------------- 72 Gran Torino "sport"- in progress
Posted By: 73GTS
Date Posted: 21-April-2012 at 3:32AM
Yeah, read the "update" post
------------- Jim
Date Posted: 21-April-2012 at 9:13PM
Fixed the broken links on my debacle. inserted images.
Posted By: BackInBlack
Date Posted: 21-July-2012 at 9:53AM
Anyone have pics using with the Energy suspension bushings mounted on their car?
I'm working on replacing the bushings right now and noticed that the over all height is different and so shimming to align will be necessary. Problem is...now where do I get the shims? The old bushing stack has a large spacer with a couple shims.
Right now...waiting for paint to dry...argh 90%+ humidity sure slows things down.
-john
------------- -John 1973 GTS
Date Posted: 24-July-2012 at 4:39PM
John, best bet is to try a place like tractor supply,etc for shim stock. You can get large washers reasonable there.
Posted By: Rockatansky
Date Posted: 24-July-2012 at 7:45PM
fender washers can usually be specified by hole size, outside diameter and thickness
any local fab shop should be able to whip out some square shims of varing thickness, the trick is to punch the holes before you go to the shear
------------- 72 GT Ute
