Print Page | Close Window
351c head gasket thickness
Category: Engine Specific Forum
URL: http://forum.grantorinosport.org/forum_posts.asp?TID=6559
Printed Date: 20-August-2018 at 1:20PM
Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: 351c head gasket thickness
Posted By: ilyes
Subject: 351c head gasket thickness
Date Posted: 22-January-2012 at 2:58AM
I've been searching and cannot find anything.
I would like to know if anyone of you knows the gasket thickness used from factory, or from those rebuild kit. I called felpro and the representative is clueless.
I plan on running as thin as I can for the gasket, while staying in MLS, I don't want to go copper and have the head machined for it
Thanks
Posted By: lynchster
Date Posted: 22-January-2012 at 5:55AM
There are two listed if I remember correctly. One is .038 and the other either .042 or .044. Again if I remember correctly the .038 is for the 2V and is worth .2 compression used on a 4V engine. I'll have to find that article again.
91 F-150
Posted By: Rockatansky
Date Posted: 22-January-2012 at 7:33AM
MLS requires special surface prep on both the block and head deck surface, specifically a smoother finish than what cast iron has been machined to
without the spec Ra finish the MLS gaskets WILL FAIL in short order if they EVER SEAL AT ALL
http://www.crankshaftcoalition.com/wiki/Head_gasket" rel="nofollow - http://www.crankshaftcoalition.com/wiki/Head_gasket
Fel-Pro 8347PT-1's and 1013's are .041"
Posted By: ilyes
Date Posted: 22-January-2012 at 11:37AM
the MLS I was looking to is 0.38" I guess it's not worth the trouble. I can't wait to pull off the heads to be sure of what they are. I saw yesterday I have some kind of fancy harmonic balancer, so I keep my hopes high for the heads, the previous owner seemed to have not looked at the prices when upgrading his car Smile
Date Posted: 23-January-2012 at 8:08AM
with the info i gave you in the other thread you don't have to pull them off to see what they are
valve cover gaskets are a lot cheaper than head gaskets
Posted By: ilyes
Date Posted: 23-January-2012 at 11:35AM
I'm gonna yank the cam and the valves, I have to remove the heads.
I wonder what cam I have, car ran 15.39 at the 1/4 mile and speed was 90 mph.
It has a 2.75 open leg, I wonder how much power it made, if you guys have an idea with those number, it would be cool
Forum Software by Web Wiz Forums® version 11.10 - http://www.webwizforums.com
Copyright ©2001-2017 Web Wiz Ltd. - https://www.webwiz.net
