1974 351/4V - Is it a CJ or not?
URL: https://forum.grantorinosport.org/forum_posts.asp?TID=8349
Printed Date: 20-April-2024 at 3:00AM Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: 1974 351/4V - Is it a CJ or not?
Posted By: unlovedford
Subject: 1974 351/4V - Is it a CJ or not?
Date Posted: 28-December-2012 at 12:50PM
I have the opportunity to buy a 1974 351 Cleveland 4 Bbl engine with 86K miles and a rebuilt C6 for cheap. Engine has been disassembled and will include new lifters, a performance cam and full gasket set. Very clean, ran fine before disassembly, he just wanted to freshen it up a bit. Will also include a new radiator. Everything looks clean and solid.
This is my question:
Is this a CJ engine, being a 1974? It came out of a Torino and I thought it would be nice to install this combo in C's Q Code if it is. Any help would be appreciated. It has the "4" marked heads, the 4 Bbl intake, but could not check in the pics for the 4 bolt mains. Complete from air cleaner case to oil pan.
------------- Joe 1972 Mom's Squire Wagon 1972 Torino Wagon 1976 Torino 1968 Cougar XR7-First batch 1972 Torino 460 1989 BroncoII/Jeeps/Titanimous Popeye and Brutus (Rams)
Posted By: GTW
Date Posted: 28-December-2012 at 12:57PM
The Q code was available in 1974, and IIRC the 4 speed was too.
------------- Griffin 1973 Gran Torino station wagon 1972 Gran Torino 4 Door 1971 Maverick 2 Door
Date Posted: 28-December-2012 at 1:24PM
Thanks, Walt! Worth the price, then.
Posted By: mcford
Date Posted: 28-December-2012 at 1:30PM
4 speed was not but Q code was.
------------- Mike
Posted By: mcford
Date Posted: 28-December-2012 at 1:31PM
72 q code will have the 2v sized valves.
------------- Mike
Posted By: 72GTS351CJ
Date Posted: 28-December-2012 at 1:35PM
Its been debated numerous times. From my knowledge if the block is marked d2ae-ca then you maybe have 4 bolt main. The only definite way to check is pull the pan.. As for the heads there is 4 and a 4 with a dot after it like this 4. Anyhow i believe you have large port heads but maybe not the desirable closed chamber heads. You won't know until you pull the head. Sorry it doesn't help but i went threw that with my motor. It turned out i had the 4bolt main block but open chamber heads. Thanks Rick
------------- 72GTS Clint Eastwood Special
Posted By: GTW
mcford wrote:
4 speed was not but Q code was. |
good to know.
Date Posted: 28-December-2012 at 1:38PM
Ah. It shows the 4 but actually has the 2bbl sized valves? That should be a bit better for low end torque. C wants something fast, so I thought this might be something to build that will move out pretty well. She is used to fast Hondas and Acuras, so it will take a bit of convincing that these need a bit of mental adjustment to get used to.
Posted By: mcford
Date Posted: 28-December-2012 at 2:26PM
sorry, meant 74 not 72.
------------- Mike
Posted By: mcford
no closed chamber heads after 71.
------------- Mike
Date Posted: 28-December-2012 at 3:09PM
Just looked at the pics again. There is a dot after the 4. Any difference?
Posted By: Rockatansky
Date Posted: 28-December-2012 at 6:53PM
ask the wiki
http://351cleveland.wetpaint.com/page/Q+Code+and+Cobra+Jets" rel="nofollow - http://351cleveland.wetpaint.com/page/Q+Code+and+Cobra+Jets
the dot or 'Cannonball' first appeared July of 1970, nobody knows why or what it designates. i recall there was a suggestion that it matches dots also found on castings that had been previously cast in Gray Iron w/o the dot, now cast in Nodular iron with the dot but nothing to confirm. as you can see the production run continued with Closed Chamber heads so that's not it
http://351cleveland.wetpaint.com/page/4V+Cylinder+Head+Spreadsheet" rel="nofollow - http://351cleveland.wetpaint.com/page/4V+Cylinder+Head+Spreadsheet
far as the small valve heads from 1973 & 1974, some guys swear that their virgin D3 heads came from the factory with large valves, could have been a mid-year change for emissions, driveability, or just because they were out of big valves?
------------- 72 GT Ute
Date Posted: 28-December-2012 at 7:13PM
how sure are you that it's an untampered 1974 production engine?
there's an engine build date code stamped in near the timing pointer tab, and cylinder head cast date codes under the valve covers, for the heads to possibly be original to the block their cast date code should be within a couple weeks max of the engine assy date
there's no difference in the raw casting between a 4 bolt or a 2 bolt main block, all castings have the bulge provision in the bulkhead where they get drilled for the outside bolts, only way to know is to look
is the air cleaner cover missing? if not, what's the decal say on it?
also curious what cam you're getting, any info on it?
Date Posted: 29-December-2012 at 1:58AM
I am mostly sure that it has not been tampered with, only disassembled and is a 1974. The owner is sick and needs the money.
Air cleaner case is solid blue, the large diameter, says 351-4V, lists Regular fuel, is marked FRONT, and has the arrow pointing that way.
Cam is in the box, is an Erson, Erson lifters, Motorcraft head bolts. All unopened ans in the original packaging.
Starter, all pulleys, motor mounts, accessories, coil, everything included.
Radiator is new and in the box.
C6 has been rebuilt.
I am going off pictures listed in the ad. He is asking $400 for everything and I just wanted to be sure that it was worth that before going further. C wants something that will hold it's own on the strip (thanks Alex and Allan) and that she can get a serious thrill out of racing. It will also be driven on the street to work and such. She is so used to smaller, lighter cars that I am having a difficult time getting her to understand that her Acura can run sub-6 second 0 - 60 times and hit triple digit speeds easier, faster and less expensively than an older heavier V8 powered Torino. I do not want to go the 429/460 route because of weight (she also wants it to stop and handle well), so I am in a bit of a quandry.
Anyhow, I need some advice on this, as I could build and keep the engine as a spare for my 4 speed car, sell the C6 and use the radiator in a future project if you don't think it is a feasable venture. Price seems awfully cheap to pass up.
Posted By: occupant
Date Posted: 29-December-2012 at 3:50AM
Joe, if you get a chance to take some pics of the cam card and what part number, that would be sweet, because I'd like to have it as a reference for when someday I take this engine apart, to know what cam is in there, it's supposed to be an Erson RV cam of some kind but I can't find ANY info online about them.
------------- 08 Uplander LS, 262K, broken again 08 Explorer EB, 195K, for the wife still looking for another something
Date Posted: 29-December-2012 at 5:26AM
i wouldn't pass it up, as you say you can either use it for the build your wife is doing or use it up in pieces for your own stuff, but i think it's just what she needs
i found some Erson info in these pages
http://www.osorracing.com/cams/cams.htm" rel="nofollow - http://www.osorracing.com/cams/cams.htm
Posted By: Regul8r
Date Posted: 29-December-2012 at 7:46AM
$400 is worth it
------------- Carl Corey (Moderator/Event Coordinator) Contact ANYTIME! 1976 Ford Elite "Lola Mae" 97 Suzuki Intruder 1400 US Army Retired
Posted By: stanman
Date Posted: 29-December-2012 at 8:09AM
In mostly stock form my '72 CJ, which had the smaller valve open chamber heads, did the quarter in around 15.2....not bad for a land yacht. That's with a 4 speed and 3:50 gears. I think Catherine will be satisfied with that.
Posted By: kenneth
Date Posted: 29-December-2012 at 8:17AM
Ask him to drop the pan for you and photo (assuming its out). Not sure about the 74 but it should have the 4MA crank in it too.
------------- 1973 Q code sports roof
Date Posted: 29-December-2012 at 10:53AM
not sure what the differences between the 4M / 4MA / 4MAB cranks are, but if it's a 1974 build i would guess it might have the latest 4MAB revision crank in it?
the only different crank i'm aware of would be the genuine Boss D1ZX-AA crank, it has a slightly different imbalance but otherwise should physically interchange w/o issue just like the others. i wouldn't doubt that the D1ZX crank was spec'd for slightly more oil clearance from the factory also
http://www.network54.com/Forum/119419/thread/1230378948/Boss+351+crankshaft" rel="nofollow - http://www.network54.com/Forum/119419/thread/1230378948/Boss+351+crankshaft -
as far as being 2 or 4 bolt, i wouldn't let that weigh to heavily on the decision @ $400
Date Posted: 29-December-2012 at 10:56AM
stanman wrote:
In mostly stock form my '72 CJ, which had the smaller valve open chamber heads... |
no small valve CJ's in 72, the only small valve OC Clevelands in 72 were 2V's
Posted By: stanman
Date Posted: 29-December-2012 at 12:17PM
I beg to differ. I bought mine in 1978 with 36,000 miles. Showed no signs of ever being apart (but could have been, I suppose). Not sure if they were 2V size but they weren't the 2.19's like the closed chamber. Also had the 4 stamped on the corner of the head. The engine is stored away in my garage. If I get a chance I'll take off a valve cover and see what the casting number is on the head. Maybe replacement heads, maybe a late in year production, but they were there when I bought it....And the block is 4 bolt mains.
On the subject of 4 bolt mains, I don't think they increase the strength of the Cleveland block any great amount. My theory is Ford went to 4 bolt to compete with Chevy's 4 bolt. In a GM, the extra bolts do increase strength because the main bolts are smaller than the Ford's. The Ford 2 bolt mains are supposed to be safe to (I think) 6500-7000 RPM's (?).
Posted By: mcford
Date Posted: 29-December-2012 at 3:53PM
my builder told me that with good rod bolts and a balance job, a 2 bolt block is good to 7000 rpm's.
------------- Mike
Date Posted: 29-December-2012 at 4:13PM
Well, I talked with the gentleman this afternoon, and got some additional information on everything. The drivetrain was in his grandmother's '74 Torino. The car had 86K actual miles and was hardly driven over the years. When he took possession of the car, it was running well, but had a small noise coming from the front of the block. Since he was intending on getting a '72 F100 to restore, he pulled the complete drivetrain to use. Since the engine was out, he tore it down and found that the noise was some of the plastic teeth had come off the timing chain and that nothing was wrong with the engine. No need to bore it, just a nice hone needed.
C6 transmission is completely rebuilt by a local reputable builder here in town and has never been installed.
Radiator is new in the box, never installed.
Erson cam is an "RV" cam (perfect for his F100 truck project), lifters are Erson, head bolts are new Motorcraft, gasket set is FelPro. Block looks great, heads are redone with a port and polish, pistons are fine, crank needs just a simple polish.
2 sets of Torino motor mounts, A/C compressor, PS pump, Alternator, all pulleys, belts, coil, flywheel, air cleaner case, etc all included in the sale. Several large boxes of things.
I feel really bad for him, as his health is not well and he is moving. I made him an offer and he accepted. Going to inspect everything in the morning and load it up.
Posted By: torkair
Date Posted: 29-December-2012 at 9:00PM
Nice find there, I'm still waiting for the day that I can stick some CC 4v heads on the 400 in the Ranchero since it is also a factory Q code.
------------- 72 Gran Torino "sport"- in progress
Date Posted: 29-December-2012 at 10:00PM
RV cam = let's wait till you have some numbers
for me to keep a clear conscience i need to suggest;
that you replace the rod nuts with new, the stock rod bolts are fine but the nuts fail. miniscule cost & very easy ARP 200-8604 by the 'each', 200-8624 is a 2-pack, or 200-8634 is a 10-pack
and that you consider replacing the stock valves with new 1 piece units. the stock valve stems are friction welded to the heads. they don't stay welded, sometimes even at idle
Date Posted: 30-December-2012 at 3:04AM
Excellent advice. I will surely do everything to ensure I don't have to pull it apart again.
Date Posted: 30-December-2012 at 7:40AM
Picked everything up. Guy was super nice and helped load up. I took pictures of the intake numbers as well as the cam info.
Date Posted: 30-December-2012 at 7:51AM
Posted By: legend onirot
Date Posted: 30-December-2012 at 2:59PM
been out of town... i leave for a week and you bought another one? you are making it very difficult for me to catch up to you....
------------- --------------------- malcolm 1973 gran torino sport (formal)... "Stacy Lynn" 1972 gran torino (formal)... "Mackenzie" 1973 gran torino sport (sportroof)... "Leela"
Date Posted: 31-December-2012 at 6:49AM
alright, for the record it does appear that Ford assembled some 'D3' large port/small valve Clevelands during 1972 model year production
http://www.network54.com/Forum/119419/thread/1356932892/what+valves+are+in+this+chamber" rel="nofollow - http://www.network54.com/Forum/119419/thread/1356932892/what+valves+are+in+this+chamber
never say never about Ford especially in model year transitions
Date Posted: 08-January-2013 at 3:00AM
Found the specs on the new cam. Erson RV10H #E220101. Great cam all around, good RPM range, good fuel economy.
I am also attaching a link to an Erson/Ford PDF. Very good info on cam selection for all Ford engines.
http://www.american-automobile.com/Erson%20ford.pdf
Date Posted: 08-January-2013 at 5:06AM
it's a RV cam!
kind of an anomoly with only 208* @ .050" and 280* total, it should pull the lowest gear
set you can find with a stock converter if that's what you're lookin for? looks to be the same grind as Elgin E-1155-P with 62* overlap, right at about the max for a street Cleveland
rated for 1000-4000 rpm it's gonna run out of wind real fast with any gear much
over 3.00 / 3.25 ~maybe
is it a 4 bolt block?
D3 small valve heads?
there was a Super Stock guy that used to post, he said the small valve heads were the best to start with because they have material in the valve bowls that the big valve heads don't have... a porter that knows what to do can use that material to cause the intake charge to swirl more efficiently through the valve bowls and they make more power than factory large valve heads
Posted By: occupant
Date Posted: 08-January-2013 at 6:00AM
If that E220101 is what is in my car, explains why it doesn't pull much over 4000 (when it's running right). I'm willing to bet that is what is in there.
Makes me want that CompCams DEH265 that much more! And a straight up timing set!
Date Posted: 08-January-2013 at 3:22PM
Alan, the 'straight up timing set' is kind of a phalacy, some brands of aftermarket double row timing sets are based off of the retarded keyway & dowel positions. Ford changed both the crank sprocket And the valve timing events themselves as they are ground on the cams beginning around 72. one of the cams was identical to the previous model year revision except for being 4* retarded, others had their events altered slightly all being retarded by various amounts
because of the varying amount of retard of certain valve events, sometimes simply advancing the cam works gangbusters, but with some cams it will palce certain valve opening or closing points too early for the cam to perform properly causing low power or not so hot fuel consumption
here's a comparison i did of 3 crank sprockets i had on hand at the time, unfortunately the stock silent type chain crank sprockets have a different number of teeth so a direct comparison isn't possible. all 3 are in the zer0 position, the front & rear sprockets are very close but not the same and the middle one is way different
the only way to set your cam and be sure it's where it's supposed to be according to the manufacturers design, or where you want it to be different from there is to degree it. i got pretty creative with the gear teeth to get one just where i wanted it, because the available -4*, 0 & +4* didn't get me there i started experimenting by skipping a tooth on the chain and using the +/- positions. between the advance ground into the aftermarket cam, and the advance / retard positions in the crank sprocket it can get pretty confusing, here's a pic of the timing set marked with a sharpie and set up in a skipped tooth position. i don't even remember exactly what i did here but it ended exactly where i wanted it. i think i skipped a tooth to retard for 10*, used the advanced keyway and with the advance in the cam grind it ended up about 1/2 of the ground in cam advance for a 108* intake centerline... maybe it was 110*
Posted By: occupant
Date Posted: 09-January-2013 at 3:54AM
Gosh, that's confusing. I get what you're saying, and I get the theory behind it. But it makes me want to just shove a Silverado 5.3L LS engine in my car and be done with it
Posted By: HOSSENPHEPHER
Date Posted: 09-January-2013 at 4:39AM
occupant wrote:
Gosh, that's confusing. I get what you're saying, and I get the theory behind it. But it makes me want to just shove a Silverado 5.3L LS engine in my car and be done with it |
Ditto that... but after reading that, I'd probably pay someone to do either. Which means I wouldn't have it done cause that would probably cost more than I care to pay.
------------- Robert; Memphis(ish), TN Occupation: I count stuff, but not well Future owner of a 1972 Ford Gran Torino Sport - "No name"
Date Posted: 09-January-2013 at 4:50AM
there are 9 keyway crank sprockets available from several manufacturers, that should make it a lot less confusing
the old school way was to use either offset keys &/or drill the dowel pin hole in the cam sprocket oversize and use offset bushing inserts to change the position of the dowel
Date Posted: 09-January-2013 at 7:20AM
I would be afraid of my reaction after putting it back together, only to find it was worse.
Posted By: stuck
Date Posted: 12-January-2013 at 3:07AM
the small valve 74 4v heads are interesting to me for a alcohol/e85 set up using a larger intake valve then might be available in earlier heads.
------------- michigan
