Project TV 2M8O |
Post Reply | Page <1 3031323334 42> |
Dan the ranchero man
Senior Member Joined: 24-July-2011 Location: Mchenry,IL Status: Offline Points: 1174 |
Thanks(1)
I would take the belt off and in the center of the pulley is a spot for a hex drive. I put a hex (don't remember the size) on the end of a drill and run it. Have someone "slowly" turn the steering wheel. You should feel on the drill end the pump working (have the front end up when doing this). In some cases depending on the torque of your drill turning the wheel might even stop the drill (so hold on tight)
handsofstone
If it was cycled through the stops I can't see it getting air in the system again. Is the pump installed correctly in the reservoir? Not sure if it could be installed on the engine that way but is something to consider.
TV 2M8O
Senior Member Joined: 20-September-2006 Location: Southern Ohio Status: Offline Points: 2052 |
OK guys, I'm trying to devise a way I can watch/cycle/fill the power steering system solo because I'm tired of waiting on help that just seems to push my project farther and farther behind. What I'm envisioning (and correct me if my thinking is incorrect) is..... temporarily replace the return line from the cooler and the return inlet on the pump with a clear piece of hose to monitor the fluid flow and fluid state (foamy/fluid) and also to insert a clear piece of clear tubing tightly into the pump fill tube with a reservoir on top to monitor fluid level.
My first step would be insert the clear hose between the ps cooler and the pump, install and pour fluid into the "fill reservoir" and start the engine. (At idle, I should be able to see the fluid flow thru the system "at rest" correct?) Keep watch on the fluid level/flow until it looks like there is no more foam/air in the line. Once the fluid is running clear, S L O W L Y cycle the steering from stop to stop, keeping an eye on the fluid level in the reservoir, until I can feel steering assist and the fluid once more flows clear. When fluid is flowing clear, set the wheels back on the ground and confirm steering assist. If everything is good, syphon fluid from reservoir and fill tube, remove clear return line from cooler to pump and reinstall normal return line, start engine and check pump fluid level and top off as necessary. Am I on the right track?
handsofstone
You are making this out to be way more than it is. Fill it, run it, cycle the steering, engine off, check fluid level, and close hood.
The factory didn't spend more than four or five minutes on the steering, if that. They had too much to do and it was allotted x amount of time per station.
I think your method will work, but I have kind of always followed John's method above for P/S. Fill, cycle it back and forth and go. I have never had an issue using this method. But in your case, maybe the pump is bad, so the clear hose may help to see if it is actually pumping fluid. When you cycle the wheels back and forth you should hear the pump working.
handsofstone
I have a funny feeling the pump is installed upside down in the reservoir. Will look in the manual in a bit.
handsofstone
Thanks(1)
It sure looks like it can be installed incorrectly in the reservoir.My camera is terrible. Sorry about that.
TV 2M8O
John,
Digging back thru my pictures of the pump disassembly and reassembly, I came across these two.... this one is with the pulley and bracket removed but the reservoir has yet to be popped off the pump. With the large square boss at 12 o'clock, it looks like the fill tube is between 10 & 11.... here the rebuilt pump is with the reservoir and bracket reattached but the pulley is not in place just yet. Looks like the square boss is again at 12 and the fill tube is just before that.... so I think the pump is in the can correctly. Do you agree??? I appreciate your input and did just as you suggested a few times before setting back down on all fours which is why I'm trying to determine if the issue is the pump or the Lares quick ratio steering box since both are new or rebuilt parts. Again my thanks....
handsofstone
Looks right to me. Sucks that you have o deal with it. Do you have a spare pump you could try? I am no expert by any means but would try a small camera in the filler tube first rather than a clear hose on the return. Did you build the pump? Not sure if the pump housing assemble can be installed 180 degrees from where is should be or not. Hard to tell in this pic.
handsofstone
Pic shows two pump internals. One has fitting in center, the other is iff to the side.
I am leaning towards the pump being the issue. If it were the steering gear, the pump would be dragging the rpms down a bit and/or squealing bad. Almost like a slipping belt.
handsofstone
You could put a cap on the return fitting on the reservoir and extend the hose enough to put an end in a can. Remove the coil wire and use a remote starter switch to bump the engine a couple of turns. If the pump is working, you will know pretty quickly.
handsofstone
I am not certain as to whether or not it can be assembled backwards. These are from a youtube video. I am hoping it is the pump for your sake.
idk those pumps are pretty simple... i rebuilt my original one $12 kit from car quest, then i ground down the square tab to gain more clearance for belt adjustment with my billet bracket (not good as i ground through an oil passage there welded it back up but it always seeped!!! thought it was the reservoir o ring!!!) just turned it in for a core for another rebuilt unit
could be a check valve issue somewhere???
handsofstone
Has to be something simple with lots of pain involved. Lol
mkshelton
Senior Member Joined: 14-March-2012 Location: Sierra Vista Status: Offline Points: 357 |
I hope that I'm wrong, but could it be that one of the plastic line plugs on the steering box is still in place?
If so, that would be something I would do. "Dooahh"
handsofstone
That would make that pump scream. I am betting on the pump being no good.
TV 2M8O
Pretty sure I had to remove the plugs to screw the hoses into the ports.........
Rons73
Member Joined: 22-November-2018 Location: Alberta Status: Offline Points: 146 |
Thanks(1)
Tough when you are dealing with a problem that has more than one unknown component for sure. The pump is probably the only one you can troubleshoot at all but it might get messy. I would plug/deadhead the pressure port or line and try to turn the pump by hand or with an angle drive drill or whatever you have clearance for. The pump should really stop/resist your efforts if working. Perhaps the bypass valve is faulty, giving you some fluid flow, but no pressure for assist?
TV 2M8O
A bit of digging back thru the forum and I came across this link to a Ford Power Steering Pump Diagnosis and Testing manual....
Going to print it out tomorrow and read thru it hoping for a solution before pulling the pump off and going thru her again..... Thanks all!!
TV 2M8O
From what I've read in all the possible suggestions I've gotten, I'm leaning towards the issue being with the pump because it's not making ANY noises that it should if there's a restriction elsewhere. Pretty sure I followed the rebuild directions to the letter but I could have misinterpreted something it said to do. gonna pull it off and try again tomorrow......
Wish me luck!!
handsofstone
Watch a YouTube video, there are some good ones that may give you the answer quickly.
handsofstone
And good luck.
Rons73
Hope it is something simple! Good luck!
Good luck Joe, hopefully it's just something small inside the pump. I don't suppose you have a working old pump to swap out?
Worst case scenario, it looks like the pumps are still readily available. Even Lares has one. |
yes you can get a rebuilt one pretty reasonable i think mine was $30-40? get it without the reservoir can!!! it's way cheaper!!!
TV 2M8O
Well after pulling everything of the driver side of the engine to get the power steering pump out...
I called the patient expired at 2:32pm today. Seems the pump valve assembly is seized in the pump housing... Tried to knock it out, but that baby is in there!! Time to just order a reman.....
handsofstone
Well done doc.
handsofstone
Parts store has the pump in stock, get it done. 😉
TV 2M8O
Lares 2014 reman pump ordered......
