Project TV 2M8O
 Post Reply Post Reply Page  <1 3435363738>
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2017 at 5:52AM
AHHHHHH!!! this is just like T.V....just when it's gettin' good , f**king commercial!!!!Angry LOL
 gettin' there joe , damn you should be close to paint WinkClapClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2017 at 6:15AM
I also drug out the front & rear bumper reinforcements to see how I could reduce their mass and weight by a cutting away some of the metal.
i'd leave the rear alone & swiss cheese the front, weight in the rear is gonna be your friend Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2017 at 7:24AM
Good point Max... THANKS
Johnny, I'm really close, but now I need to find a new shop to handle the body and paint. The shop I was gonna use is closing it's doors the end of September. My target it to have it in the body shop before the holidays... if I can find a shop I feel can do the work to my standards. I'm kind anal! LOL
Edited by TV 2M8O - 17-September-2017 at 7:24AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2017 at 9:23AM
oh i know what you mean!
i thought the owner was still going to do it for you at his house??? or did he flake out on you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2017 at 10:51AM
John,
He still wants to do it but I'm concerned about the quality until I see how his home shop is set up. Come too far to let it get screwed up now!!! Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2017 at 2:11PM
true!the guy with the knowledge makes a big difference the shop, well i can tell you i've done some damn nice paint jobs in a dirt floor garage Shocked not that i'd recommend doing that lol, and i've done some in a shop that was like an electronics "clean room" and every piece of dust and lint from 2 counties found it's way into the clear!Confused....
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2017 at 4:54AM
Well Saturday sucked sand..... NO REALLY, I sucked sand most of the day! LOL, I had to vacuum up all the sand from the blast booth so I could continue blasting the deck lid and a few other major components that can't fit into the blast cabinet. Had I remembered, I could have done that last Saturday while recuperating from elbow surgery rather than waiting around at the house for F3 to let me know they were at the shop to pick up my windshield and heated back glass!
Here is my little bucket blaster that has served me well in blasting the undercarriage and other larger items on this build
as well as our blast cabinet for the smaller stuff.
Once I was finished vacuuming and sifting the sand into 5 gallon buckets, I check my alternator captive nut to verify it would work as envisioned
and got that all put together
and then hung the rear tires back on the dormant T'bolt tribute project to once more have it a mobile project.
Next weekend hope to get the sheetmetal blasting all knocked out.
Edited by TV 2M8O - 01-October-2017 at 5:16AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2017 at 6:31AM
uh-huh several vehicles in various states of disrepair Thumbs Up (lol i know the feeling Wink)
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 15-October-2017 at 9:34AM
A wee bit of progress this weekend... CaliforniaJohnny sent me a proportioning valve like is on the Tomato.
It allowed me to make a distribution piston stop (install in place of brake switch to keep the piston centered while bleeding) as well as determining how to recenter the piston in my proportioning valve.
Simple as taking a 3/32" dia round (the cross bar from a wire coat hanger in my case!)
and gently tapping the piston forward in the distribution block until the center divot was visible in the switch opening.
I'll install the stop to keep the piston in place until we get the back brakes bled. Once both systems are bled and I have a firm pedal, the stop will come out and the switch installed back into it's proper home.
Once that was finished, I went into the blast booth and blasted a bit more on the deck lid. Just about finished on the outside...
then I'll flip it over and do the inside. Oh what fun!
The next two weekends will be unproductive... I have a doctors appointment next weekend at the Cleveland Clinic and the following weekend is our annual wedding anniversary Halloween party.
Edited by TV 2M8O - 15-October-2017 at 9:38AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 15-October-2017 at 7:16PM
Clap looking good joe! i'm surprised that valve wasn't centered it came off a nice car with working brake system!!! must have moved during shipping?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 15-October-2017 at 10:13PM
John,
The valve you sent me WAS centered, I used it to determine if my idea to try and push mine back to center would work. Now I'll use yours as the rebuild model to see if they can truly be rebuilt easily with the parts kit I found on line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-October-2017 at 3:19AM
Thumbs Up ah ok
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 05-November-2017 at 7:06AM
Well after having a very unproductive October, I had a bit of progress this weekend... we got the rear brakes bled, the wheels back on and the Torino is ready to set down on the ground.
I then moved into the blast booth and fought with the sandblaster. Seems I forgot to turn off my air line the last time I blasted and both water traps were full of water. I drained them both but evidently there was still moisture in the air lines because I could not get the media to get siphoned into the blasting pickup line, so I reverted to the old scotch-brite pad on the angle head as well as the DA to get the remaining paint off the top side of the deck lid.
I did use the sandblaster to blow off the decklid once and the media started to be picked up, so I was able to do a bit of sandblasting on the remaining paint until I stopped to answer my phone. Once I finished and resumed trying to blast, evidently the moisture had built back up in the line so I had to revert back to manual stripping. Need to check on perhaps getting new filters/desiccant for the Sharpe water traps???
Next weekend, I'll flip over the deck lid and blast (hopefully!!) the underside and then start on the driver side front fender. Once the fender is clean, all body sheet metal will be stripped and I can protect and prep it all with a coating of Ospho until the Tomato is back into the body shop.
I like the sound of that!!!
Edited by TV 2M8O - 05-November-2017 at 7:12AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-November-2017 at 9:07AM
it should siphon sand unless you have visible water coming out the gun??? i use the sediment bowl style water traps they work good! unless you forget to check them and they are full Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 12-November-2017 at 9:12AM
Well another unproductive weekend, but I think I've found the solution to my sandblasting problem.
Another weekend trying to blast that was filled with frustration. I drained the air compressor as well as the air line filters into the blast booth, but could not get the sand to pick up. Then I remembered the disposable water trap I had installed on my paint gun, so I removed it from the paint gun and attached it to the blast gun air line and the media began to flow!
Got about 1/3 of the seam sealer blasted from the underside of the decklid before the media stopped flowing.....
I called O'Reilly's and ordered two filter elements for the Sharpe oil/water traps installed on the hard lines and will make a run to Harbor Freight this week to buy a couple of their inline desiccant dryer/filters to see how well they perform at resolving my moisture issues.
I also noticed some areas on the underside of the decklid that Ford missed as well as the 2B respray a few years ago...
Seems with the decklid mounted on the car, it must be difficult to see to hit the backside of the rearward decklid bracing. I'll make sure mine gets painted as all the body panels will be painted off the car and rehung during final assembly.
Well hopefully next weekend will be much more productive and I'll get the Tomato that much closer to going to the body shop for final fit and finish. Fingers crossed!
Edited by TV 2M8O - 12-November-2017 at 9:16AM
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 12-November-2017 at 9:48AM
Joe, I went through the same frustrations with my blast cabinet.
Here's what I suggest to help....
Get yourself a 25 or 50 foot air hose. Hook it up to your compressor, and then LEAVE IT COILED UP. Put a compressor water separator at the end of the coiled hose, mounted to a workbench leg or something similar. Then run your regular air hose off the separator.
This should cure the majority of your moisture issues. Most people (like myself!) make the mistake of putting a water separator right off the compressor, but installed at that point, the speed of the air coming out of the compressor just blows the water vapor over the separator. The coiled hose will allow the water vapor to condense, where it can be better caught by the remote separator.
Try it!
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 12-November-2017 at 12:26PM
Thanks Sal for the tip! Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-November-2017 at 3:44PM
yes sal is right!! if the separator is right off the compressor the air is heated and any water is vaporized! as it travels down the line it cools and condenses forming water droplets!!! i use a separator similar to this way down line Wink
1/2&quot;  Particulate filter water trap seperator moisture Compressed Air Compressor
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 13-November-2017 at 10:47AM
There's a Sharpe 606 & Sharpe 606B at the end of the hard line where the air hose is attached. Gonna change the filter elements in both and add the inline desiccant dryer/filter at the blast gun. That should resolve my issue (I HOPE!!).
Gotta get this baby back to the body shop ASAP!!!!!
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-November-2017 at 5:44PM
Wink
btw i'll send out your bumper bolts soon as i get a chance Wink
This page was generated in 0.098 seconds.
