Project TV 2M8O
 Post Reply Post Reply Page  <1 363738
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-January-2018 at 6:10AM
how the hell did they cause that severe of a dent in that area?Shocked i looked at a dented hood i have but that area by the latch is rotted badCry
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 21-January-2018 at 10:21PM
John,
Kinda looks as if it was hammered down for clearance of something once upon a time???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2018 at 11:01AM
Had one of those kinda dents on the montego hood. It was from someone trying to pry it open.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 28-January-2018 at 8:39AM
Productive day today... got the underside of the hood
and deck lid coated
with Ospho as well as both headlight buckets,
the grill header and front bumper steel sight shield.
Also painted a couple brackets and pulled out the NOS C6 cooling pan I got this week...
NICE!
Next, I'll flip the hood and deck lid and coat the top sides with Ospho and start gathering up the hardware to start rehanging the sheet metal for the trip to the body shop.
Edited by TV 2M8O - 28-January-2018 at 8:41AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2018 at 1:26AM
Last weekend, I took a little hiatus to run up to North Canton, Ohio to pick up this little filly and bring her home with me...
Made a bit more progress this weekend as I got the top side of the hood and deck lid, along with the rest (98%??) of the sheet metal, prepped with Ospho...
Now the snipe hunt begins to find all the fasteners to get the panels rehung and the Tomato off to the body shop!
Edited by TV 2M8O - 11-February-2018 at 1:29AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2018 at 6:04AM
try these guys!  http://www.amkproducts.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2018 at 6:33AM
Dan, I meant in my parts cache... tho AMK is where I go to replace unusable or missing hardware. Thanks for the link!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2018 at 5:55PM
i had hoped you put them in ziplock bags and wrote on them with a sharpie? some laughed at my idea but it pays dividends at a time like this!!! and keep all the bags in one big box Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2018 at 10:06PM
I either ziplock and tag them or leave them threaded into the part, but I remember taking the large fender washers and bolts out as I was prepping the fenders and not too sure where I put them. Pretty sure I have already blasted them so I'll spend this weekend getting all the hardware and associated bracketry located and laid out for rehanging the sheet metal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2018 at 4:55PM
Joe, you mean the large washers that go under the fenderwells?
If you need any let me know i saved several from those parts cars just in case someone needs any
Edited by californiajohnny - 20-February-2018 at 4:56PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 17-March-2018 at 9:26AM
Have had somewhat of a necessary break in progress the past few weeks as I've had to stay home and keep an eye on my Mom who is slowly slipping away from us. But there has been some progress and I was able to go over today and do a bit of work on the Tomato....
Last weekend at home, I was able to get all the necessary pieces to assemble my temporary heater bypass hose...
and this weekend I was able to finally heat shrink the hose clamp and get the hose loosely fitted to the engine...
dry fit the driver side wheelhouse to the fender to get an idea of what hardware I need...
painted the wheelhouse to fender washers...
blasted, wire wheeled and got the first coat of bluing on the headlight adjustment springs...
and cruise control mounting bracket nuts...
and got a coat of chassis black on the backside of the headlight buckets and grill header panel.
This week I'll order the necessary hardware I'll need to get the fenders, headlight buckets and header panel remounted to the car and I'll be one step closer to turning her back over to the body shop for final bodywork and paint!
Edited by TV 2M8O - 08-April-2018 at 1:06AM
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 17-March-2018 at 9:58AM
Looks great man keep up the good work. I have done a couple of frame off resto's and it can get very overwhelming with all the parts getting cleaned and hardware to locate/clean. Can't wait to see it done!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2018 at 1:07AM
Well after a short hiatus to deal with the loss of my Mom, I was able to get over to the dealership this weekend and do a little bit. I got the passenger door reinstalled and rehung both front wheelhouses and fenders....
Several loose ends to tie up before she'll be ready to head back for final bodywork and paint!
Edited by TV 2M8O - 08-April-2018 at 1:09AM
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2018 at 4:22AM
  looking good joe!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2018 at 7:59AM
Looks awesome Joe!  Very sorry to hear about your mother.  I have been there and it's not easy.
What's the best way to remove the front and mount the front fenders?  Remove the fenders and wheelhouse as one unit, or separately?  I see you attached the wheelhouses before you put the fenders back on.
T-Bird_79 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote T-Bird_79 Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2018 at 8:28AM
Looking really good. I like Your attention to details.Thumbs Up
Andris
1979 Ford Thunderbird
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 12-April-2018 at 5:11AM
Vince, first thanks for your condolences. Mom lived with us so we're faced with the new norm everyday and it's still odd for her not to be around. Cry
During disassembly, I removed the fenders and left the wheelhouses in place. For the reassembly of the front sheet metal for delivery back to the body shop, on the driver side I hung the wheelhouse to the fender (loosely) and fit the assembly to the car (heavy!). On the passenger side, I fit the wheelhouse then maneuvered the fender into position (lighter but had to fight to align fender hardware).
Both ways were a chore hanging solo, but I think for final assembly, it would be preferred to hang the wheelhouse onto the fender loosely so all the fasteners into the fender can be started to alleviate alignment issues and scratching/damaging the final paint. PLUS, it's definitely a two man job!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-April-2018 at 11:32AM
 what?! i did mine by myself CryLOLWink
