Project TV 2M8O
 Post Reply Post Reply Page  <1 262728
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2018 at 12:19PM
starting to look like a car again joe Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:26AM
Productive weekend. I installed the vacuum sensors into the water passages...
checked all hose connections were tight (or so I thought) then filled the cooling system with the Evans Waterless Coolant...
then lit off the engine and let her run!
While she was running, I dug out my AC condensers to see which one I wanted to use.
Need to clean them up and comb out the fins before making my decision. Now I need to find the mounting clips to mount it to the core support!!
Once she got hot, I had a couple leaks in the cooling system to chase down... hopefully got everything snugged up and sealed off! We'll know more next weekend….
Edited by TV 2M8O - Yesterday at 7:27AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:38AM
getting there joe! as long as the rubber mounts are good! most of the cars i parted the mounts broke trying to remove the nuts!!!Angry but i may have the brackets if you need any?
