Project TV 2M8O
 Post Reply Post Reply Page  <1 293031
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2019 at 11:40AM
Last weekend, I made a bit more progress... got the mounting bosses welded onto the Flowmasters this week at work...
so I hung then just to verify they work OK...
then sandblasted them so I could drop them off for powder coating once I determine how I want to do them.
Blasted the grill/header brace and shot it with a couple coats of chassis black...
and then pressurized the cooling system looking for the leaks. Only visible sign was a bit of seepage around the radiator drain petcock. Got a spacer to extend it out a bit farther beyond the core support flange and I think I'm going to replace the thermostat gasket and the mounting hardware with slightly shorter bolts to resolve that issue as well.
This weekend, I drained the radiator so I could see what the issue was with the drain petcock wings hitting the core support flange. Since I couldn't open the drain all the way due to the interference, it was a long and agonizing process that seemed to take forever!
Once the level got below the upper radiator hose level, I pulled off the upper hose and thermostat housing to replace the gasket. Evidently the gasket that came with the thermostat (or the one they sold me with the thermostat?) was a junk paper gasket that was totally mush when I pulled the housing off the intake manifold. I coated the Fel-Pro gasket with gasket sealer and stuck it onto the hose outlet housing awaiting re-installation. Also checked the thread depth on the housing mounts into the intake manifold and they're plenty deep enough for the stock hardware, so the issue was entirely that gasket.
When the radiator had finally stopped draining, I removed the lower radiator hose, transmission lines and fan shroud then removed the upper hold downs and pulled the radiator and drained the residual coolant into the catch pan.
Comparing the replacement radiator with the OEM radiator, I found that the drain hole was 1/2" lower in the new one accounting for the interference. I trimmed away a portion of the rubber lower insulator to clear the petcock wings and also plan on taking a die grinder and adding a slight relief to the core support flange for that extra little bit of clearance.
Once these two issues are resolved, I (hopefully) will have no further coolant leaks!! ... and by the way, that Evans Waterless Coolant is the oilest stuff ever. I thought regular coolant was bad, but this stuff is almost impossible to wipe up, but once my leaks are resolved, I should never have to deal with it again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2019 at 12:06PM
Looks great Joe.  Hopefully you finally got that coolant leak resolved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2019 at 1:52PM
any news on paint guys????
T-Bird_79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Bird_79 Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2019 at 6:34AM
Personally I don't like those waterless coolants: this is not a miracle, you gain something, but also loose something. Ordinary coolant is mix of ethylenglycol and water plus additives to inhibit corrosion. This  is compromise between cooling capabilities, boiling temperature and resistance to corrosion. The best coolant on earth is pure water, waterless coolant, which basically is pure ethylenglycol is much worse coolant, but has much higher boiling temperature. Ordinary coolant is not as good at cooling as water, but better than waterless coolant. So what I want to say: the waterless coolant will boil at high temperature, but the engine will run hotter than with ordinary coolant. It will not boil, but it can overheat.
Andris
1979 Ford Thunderbird
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2019 at 12:17PM
T-Bird, the reason I decided to go with the Evans coolant was the corrosion resistance and boil-over protection. First time I saw this stuff was on Jay Leno's Garage, and Jay swears by it because of it's corrosion resistance with aluminum and other alloys.
Here is some info on the Evans coolant...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2019 at 12:39PM
CJ, spoke with him briefly last week and he has started building his new shop and won't be taking on any new projects until about September, so I have time to get a few more systems dialed in before handing her off for bodywork and paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2019 at 6:48PM
 Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 09-June-2019 at 7:09AM
A little bit of metalwork this weekend. Added the clearance radius for the drain petcock wings...
and trimmed the core support for clearance around the transmission cooler hoses...
I'll have to leave welding it in to the body shop because the welder won't reach from where it's setting.
Next weekend, I'll reinstall everything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-June-2019 at 8:34AM
welder won't reach... what are you using for a welder? thin sheetmetal i'd think you're using a 110v wire feed?...extension cord Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 09-June-2019 at 10:17AM
220V Miller mig........ no extension cord.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-June-2019 at 11:50AM
Shocked
