  New Posts New Posts RSS Feed - PS flush
PS flush
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Topic: PS flush
    Posted: 26-November-2016 at 1:24AM
Finally finished replacing the PS pump. What is the best way to flush the lines, the steering box and pump itself? Also, is the power steering cooler a huge necessity? Don't have the A/C compressor that it hangs on anymore, but I could always get some rubber line extensions and mount it on the frame somewhere. I just don't want a dorky looking install with it hanging where I'll scrape my knuckles on it on a regular basis. Does everyone still use it?
Matt
1969 Mercury Marauder 390
1972 Montego MX
2003 Mercury Marauder 300A
1994 F-150 5.8
2016 Ford Fusion Titanium
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2016 at 1:35AM
You're gonna want to keep the cooler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2016 at 3:42AM
or you can use a small trans fluid cooler in front of the radiator
russosborne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2016 at 9:25AM
this seems to be a good flush procedure.
http://turbotbird.com/techinfo/power_steering.htm
It's for a r&p style, but I don't see any reason it wouldn't work on our cars.
you can skip the first section on the turbo coupe specific stuff. Go down to the "on to the oil change" section
Russ
Edited by russosborne - 26-November-2016 at 9:28AM
