Forum Home Forum Home > Powertrain Specific Forum > FE Block Forum
  New Posts New Posts RSS Feed - Pushrod length
Pushrod length
EBERSCHEID1031 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EBERSCHEID1031 Quote  Post ReplyReply Direct Link To This Post Topic: Pushrod length
    Posted: 14-July-2019 at 6:41PM
Hi all, new here. I have a question. Heres my build:
1968 390 +30
4.25 scat crank
Flat top mahle pistons
Hydraulic roller comp cam 234@50 .587 lift 112° seperation
Lunati hydraulic lifters link bar
Harland sharp rockers
72cc edelbrock heads
Performer rpm intake
I measured pushrod length tonight and got 8.33125
Leaving no threads underside of rocker allowing 2 threads of adjustment per harland sharp. Does this number seem right to anyone with a similar 445 stroker build???
gregaba View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gregaba Quote  Post ReplyReply Direct Link To This Post Posted: 31-July-2019 at 3:24AM
Your length seems a little short. It does depend on how much head and block work was done.
I would get a good adjustable push rod and install it and get a correct measurement.
As much as push rods cost now you don't want to buy more then one set.
I would check each push rod because there is sometimes different length's for each push rod depending on your block.
Greg
Greg
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 31-July-2019 at 6:42AM
Also make sure the pushrod length is taken with the lifters internal plunger at about 1/2 it's travel, if the plunger has .060" travel you will want about .030" preload when the pushrods are installed.
This page was generated in 0.098 seconds.
