  New Posts New Posts RSS Feed - question about 460 cu in
Rivercrest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rivercrest Quote  Post ReplyReply Direct Link To This Post Topic: question about 460 cu in
    Posted: 26-January-2020 at 10:34AM
Just a quick question, did Ford put a 460 cu in into a mid 60's Torino ? Thanks to all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 26-January-2020 at 12:11PM
No, the 460 wasn't offered in the Torino until mid-way through 1973 (full year for Police cars).  The 1968-69 Torinos had no 385 series engines, just small block Fords and FE engines.  The 385 series big blocks weren't introduced to the Torino until 1970 and then only as the 429.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rivercrest Quote  Post ReplyReply Direct Link To This Post Posted: 26-January-2020 at 3:02PM
Thanks for that information.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rivercrest Quote  Post ReplyReply Direct Link To This Post Posted: 26-January-2020 at 3:06PM
BTW, would a 460 fit into the cavity where a 351 sits now. ( change of motor mounts expected )
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-January-2020 at 5:06PM
idk? you have to measure the widest part of the exhaust manifolds vs the inside of the strut towers! 71's had a 429 but idk if 70/71 are wider??? i know a guy that put a 460 in a 65 falcon and it was close, very close!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-January-2020 at 5:12PM
not sure if heidts makes a mustang II kit?  but if so then something like that will allow you to remove the strut towers giving you tons more room Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rivercrest Quote  Post ReplyReply Direct Link To This Post Posted: 27-January-2020 at 2:11AM
Thanks for the info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 27-January-2020 at 8:34AM
They will fit 68-69 using the 70-71 mounts, brackets, etc. Also might try 71-73 "Fat" Mustang mounts and brackets.
I don't think that the 66-67 is much different. 66-69 Falcon is a stubby Fairlane, chassis-wise, as are 67-70 Mustang.
Exhaust might take some looking, but headers were available for these swaps "Back in the day".
Del Griffith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Del Griffith Quote  Post ReplyReply Direct Link To This Post Posted: 28-January-2020 at 1:18AM
Hope I'm not breaking any rules, but below is a link to FE v.s. 385.
'69 Torino 2 -Door Coupe
