  New Posts New Posts RSS Feed - Question on '72 and '73 front brakes
russosborne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 30-January-2019 at 12:02AM
Just to update this, I keep forgetting to call.Embarrassed
There is an option on the website to ask where to buy, so I just did, specifically asking about part number 6028 or 6028R and if they are available in the US.
I'll let you know if/when I get an answer.
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 30-January-2019 at 12:19PM
Well, bad news.
Part number 6028R is being discontinued. 6028 already was. I can cut and paste the email from them once I get home later tonight if anyone cares.
So Raybestos is out.
I'm going to have to go to the newer 74 and up and have them redrilled. Too tired and frustrated to try to find these Thunderbird ones anymore.
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 30-January-2019 at 2:06PM
That's disappointing.  It would be even worse for a guy that owns a '72 Bird or Mark IV, no replacement rotors available for those cars now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 30-January-2019 at 3:02PM
change to small rotors and caliper brackets, or change spindles & redrill 74+ police rotors
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-January-2019 at 3:32PM
russ, i sent you 74 spindles Wink you can go with big brackets and 12" 74+ lincoln rotors Big smile redrill if you're fond of your particular on the style wheels you have
 good news for you russ... the front pan section you still need i may have available for you ( just need to confirm with my own eyes if his drivers pan is good in his car, he says it is but)
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 30-January-2019 at 4:32PM
Yes, you did.
That's been my backup plan, was hoping I could get the Tbird rotors though. Bolt on is always my favorite way to do stuff.
Let me know when you are sure either way about the pan.
Thanks,
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-January-2019 at 7:07PM
i will, do you have the big brackets?
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 30-January-2019 at 9:06PM
Yep. Got them from another member here.
Thanks,
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-January-2019 at 3:05AM
ok i thought you did
