Radiator Missing Need Help |
72TorinoRoth
New Member Joined: 30-April-2021 Location: Oak Harbor, WA Status: Offline Points: 22 |
Posted: 07-June-2021 at 2:06PM |
I’m missing the radiator from my ‘72 wagon with 351w/FMX transmission. I was thinking I’d make more power either rebuilding or buying a crate engine. I found this radiator for a 429 auto on EBay. Price seems high. Thoughts?
handsofstone
Buy a new one on Rock Auto. Used radiators are not something I would trust, especially for that price.
$195 for a used radiator??? i have several nice ones!!! you're close drive down and take your pick $50?
72TorinoRoth
Sounds good! I’ll send you a pm.
Exodus BKG
New Member Joined: 10-June-2021 Location: Seattle Status: Offline Points: 21 |
Hey, I was curious what other Torino Elements or parts you had available. Im looking for a couple items to complete my new build. Im in Olympia, WA.
1973 Gran Torino 302 w/ C4. Looking for Interior pieces.
Exodus BKG
Not to hack up your radiator rebuild. OSC Companies offers a radiator for the 72-76 Torino 3 core.
More importantly - to properly cool you have to consider more than just your radiator. Are you running a fixed race fan? flex fan? OE? Do you have a fan clutch? Do you have a thermostat if so what's it opening up at? What is your intent for the 351? Are you going to be running a stock water pump and stock oil cooler on the FMX? I would consider adding a simple OSC 3 row radiator - sells on rockauto cheaply. Add a PowerPack in front of it from Derale Cooling w/ a PWM. Pulse Width Modulator and control your temperature on demand for your conditions. If you want a simpler set up please advise - I'm just recommending ways where you take mechanical strain off the motor - dump the fan clutch, fan blade, add clearance and efficiency to maintain your engine cool.
72TorinoRoth
I just bought a rebuilt 2 core radiator, fan shroud, 17118 Derale fan and 2710 fan clutch. I don’t know what temp thermostat to run. Goal at the moment is to make the stock engine run. After that I’ll save for a 351w crate engine from ATK making 385hp and 410 lb ft.
mark, great meeting you guys the other day, sorry things were kinda hectic
180* on the thermostat |
72TorinoRoth
Likewise. Thanks so much for the parts and the tour. Very cool. I hope to see you and Mike again sometime. And thanks for the answer on the thermostat.
