  New Posts New Posts RSS Feed - Rear bed.
Rear bed.
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: Rear bed.
    Posted: 04-July-2016 at 10:01AM
Does anybody re pop the center section of the bed.
Ranchero Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranchero Fan Quote  Post ReplyReply Direct Link To This Post Posted: 04-July-2016 at 10:07AM
For what Bob? Ranger, Ranchero, F Series,?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 04-July-2016 at 2:58PM
79 ranchero
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranchero Fan Quote  Post ReplyReply Direct Link To This Post Posted: 04-July-2016 at 3:43PM
ClapThumbs Up Starting on it? Nobody reproduces them, maybe the best scenario would be one from a donor '72-'79 Ranch., or use the replacement sections from LMC Truck parts, Mills Supply, Sherman, or similar aftermarket Co. that offers fullsize truck floors. I am not sure of the rib profiles tho. Or maybe go with diamond plate stock? If somebody out there has had any luck with a replacement that will work, PLEASE let us know. Bob ,if the floor could be media blasted, & turns out salvageable, patch, then bed line it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-July-2016 at 4:25PM
that's what i'm thinking, maybe use a whole floor from a full size?? IDK? but are all the ranches the same rib profile????? i guy i work with has a 79 that i could measure and maybe check size and rib profile against some common trucks next time i go to pick a part Wink
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 04-July-2016 at 6:21PM
There is one being parted. Maybe the seller can cut out the portion of the bed that you need. If you want to see it Click here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 04-July-2016 at 6:26PM
If you want to see another one being parted Click here. This seller said that he will only accept phone calls, no text messages and no emails.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2016 at 3:23AM
To far away.
