Rear Drum Brake Cylinder Removal |
texanrebel
Senior Member Joined: 13-June-2018 Location: Houston, Texas Status: Offline Points: 208 |
Posted: 08-January-2022 at 8:52AM |
I'm beginning to wonder if this sucker is welded on to the backing plate - any tips for a particuarly troublesome cylinder that won't budge? Two bolts removed, lines, emergency brake & bleed screw all off...used good amount of brake cleaner & WD-40. Hit it with rubber mallet all around & a few times on backside of backing plate. Afraid I might damage something if I get any more forceful...I'm replacing the wheel cylinders so not worried about damaging them...just the backing plate. 1972 Montego - thanks
1972 Montego GT
1977 Mercury Monarch 1988 Ford Thunderbird Turbo Coupe |
texanrebel
Nevermind, it finally released. Never had one this ornery...
1972 Montego GT
they can rust in there tight! dont forget to clean the edge of the backing plate real good with 80 grit or a file
texanrebel
Yep, it's gonna get some TLC for sure - pretty rusty. As soon as I get the bearings off, tomorrow. Tired pup is now going to enjoy an adult beverage & watch the rain
1972 Montego GT
Since you are working on brakes do you mind checking your rear brake drums on your car? I am assuming being a 72 it has 10 x 2" shoes. Are they Ford (will be stamped with Ford) drums or aftermarket? Just trying to figure it some rear brake drum info on these cars. 1972 is a weird year for rear brakes, a lot of one off stuff.
See the thread here: |
Eliteman76
Thanks(1)
A bit late to the party, but a lot of times on rusted backing plates...a decent wack or three with a dead blow hammer will loosen then up. Just don't forget to unbolt them. Like me in my youth lol.
Pondering: #99Problems |
texanrebel
I replied to the thread linked below Billy
1972 Montego GT
