Rear mount for AOD swap |
Gold73
Member Joined: 02-July-2018 Location: Kansas Status: Offline Points: 90 |
Posted: 29-July-2019 at 4:59PM |
I picked up an AOD to replace the C6 with in my 73 Gran Torino Sport.My question is what rear mount and crossmember should be used? The AOD was out of a 1988 F150 2wd and I have rear mounts and crossmembers from a C6 or a FMX. Info from those who have preformed this swap would be greatly appreciated.
i used an aftermarket poly mount but it fit the same as the original fmx, same cross member (i can't remember if i had to trim the front lip of the cross member for pan clearance or not??? if i did it was minor but the AOD is basically the same size, and i swapped front driveline yokes same u-joint just used the AOD yoke
Gold73
Thanks for the info John . I appreciate your reply.
Regul8r 2
Admin Group Joined: 02-February-2016 Location: Rapid City, SD Status: Offline Points: 447 |
Crossmember did not need any modifications.
I just bought a rear trans mount for an 85 Crown Vic. bolts right up to the tranny and the crossmember. |
Owner- www.CaNDeCustoms.com |
Gold73
Thanks for the info Carl.
that's a very common mount ford used that for many years on lots of vehicles matter of fact i just bought that same poly mount for my mustang and it fit the tremec 5speed
