  New Posts New Posts RSS Feed - Rear Sway Bar
Rear Sway Bar
ninoford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ninoford Quote  Post ReplyReply Direct Link To This Post Topic: Rear Sway Bar
    Posted: 10-December-2016 at 7:08PM
So I found a 78 ranchero at the junk yard and it still had the rear sway bar so I snatched it up to install in my 72. Problem is I didn't take any pictures on how its mounted. It will install either way I flip it. Or does it even matter?? If anyone has a stock sway bar can yall take some quick rear and side pictures. I would greatly appreciate it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-December-2016 at 8:22PM
it goes with the dip down, all under the diff. i have other pics but i can't find them Confused hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 11-December-2016 at 1:05AM
Good pic CJ!
 Hopefully the OP got ALL the brackets/grommets(especially the front end links), the chassis brackets for the end links seem to be a 50/50 mix of either being welded on or bolted on(may be a "year" thing). The brackets can be fabbed up easily if they weren't able to be removed(welded on), which is what I had to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ninoford Quote  Post ReplyReply Direct Link To This Post Posted: 11-December-2016 at 6:02PM
That picture is perfect! just what I needed, thanks!  I did snatch up all the brackets as well, they were just bolted on. I rebuilt the all the worn bushings with polyurethane as well, should be a nice addition.
