  New Posts New Posts RSS Feed - rear swaybar
rear swaybar
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: rear swaybar
    Posted: 24-April-2016 at 10:22AM
What do I need to put sway bar from parts car on driver. Driver never had a sway bar.
Still waiting on new stripes,hope other ones come off easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 24-April-2016 at 11:53AM
The swaybar used on the 72-79 Ford midsize car will need the following from your parts car. take both side of these parts pictured.
Then take a look at all the parts in grey that hold on the sway bar to the axel. Take all these as well.
The rubber mounts used for the end links (first photo) are no longer available. But here is the Ford part # for the end link kit. (D4OZ-5A486-A). Sometimes you get lucky and find these on e-bay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-April-2016 at 1:13PM
i can give you part #'s for urethane stuff that fits, if you need
** energy suspension bushings for the upper mounts: 9.8101g (black)
Energy Suspension 9.8101G - Shock Tower Bayonet End Style Bushings
Edited by californiajohnny - 25-April-2016 at 4:25PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2016 at 12:43AM
Thanks wonder if frame is already drilled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2016 at 1:30AM
The frame should be pretty drilled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2016 at 1:35AM
IIRC, I have seen some of the end link to chassis brackets welded in, not just bolted in. This could be on the 77-79 models, I did see where the earlier intermediates(even Marks and T-birds) had the brackets that were bolted to chassis(like as pictured above).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2016 at 11:40AM
All of the ones I have seen are bolted in and yes the holes are "in there" Thumbs Up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2016 at 1:17PM
Thanks.Did ltd2 ever have power seats? Can't find my options sheet.Know there were 60+ of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2016 at 1:38PM
Yes the LTD II's had power seats as an option. If you can't find them from an LTD II and want to stay era correct you get them out of a 77-79  ranchero/cougar or t-bird.
Edited by Dan the ranchero man - 25-April-2016 at 1:38PM
