Recommendations for a coil spring compressor for |
russosborne
Posted: 28-October-2017 at 8:54PM |
installing the front coil springs?
Will be installing the Moog 80090 springs, most likely cut half a coil, but no more than that. Will I even need a compressor? Thanks, Russ Edited by russosborne - 28-October-2017 at 8:55PM |
I installed them without a spring compressor easily. They are far shorter than stock so I don't think you'll have any issues getting them in, especially if you cut half a coil.
russosborne
I thought they were shorter, but haven't compared them side by side yet with the old ones.
Thanks! Russ |
