Forum Home Forum Home > General Discussion > How-To Articles
  New Posts New Posts RSS Feed - Recommended order of assembly - front clip
Admin of "The Org"
Post Options Post Options   Thanks (1) Thanks(1)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Topic: Recommended order of assembly - front clip
    Posted: 25-March-2014 at 5:48AM
So I got the Torino fired up. Still many things to do, one of which is the front clip. I have cleaned all the parts, performed some rust abatement on the fenders.
What is the recommended order of reassembly for the front end? The inner fenders and core support are on now. I have the front clip and fenders to put on.
Any recommendations and tips/tricks are very welcome.
Zebra 3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zebra 3 Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 12:03PM
...Thats where I am at right now with mine....putting the front clip back on...my inner fenders and core support are on now as well.....I started with the fenders w/ headlight buckets, will do the grill next (to help keep the fenders square and some what aligned) and then the hinges and finally the hood.
  Since I am a one man operation here, I am going to have the body/paint shop do the final, fine tuned, alignment
Henry Ford. 1926
Brian Conn
'76 Torino
Grantorinosport351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 12:16PM
I have tore down a 72 front end 6 times now I think
Here is my order
1. Core support
2. Fender wells
3. Put on the fenders
4. Headlight assembly
5. Grill
6. Header panel
7 hood
8 valance
9 bumper
~Bryan
72 gts h-code (formal roof)
67falcon
04 f250 ''the great white''
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 12:59PM
Here is my order
1. Core support
2. Fender wells
5. Grill
6. Header panel
7 hood
8 valance
9 bumper
see bryan, you're getting body work experience already! nothing like "hands on training"LOL
i think the 72 is a little different than mine and scott's cars the header panel would need to be on first because the grill bolts through the header and headlight assemblies through little slots
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 1:17PM
Yeah I think your right!
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 1:26PM
(if i had a nickel for every time i heard that)LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 2:05PM
1973-'76 are far easier to dismantle and assemble. Some tricks that I have learned:
Try to resist assembling the entire header/trim/headlight/mouldings/grill assembly and then pick it up to move it by yourself. The trim bends easily.
Mount the bumper/metal center filler last, if you have guards.
The end rubber fillers need to be mounted with the lower headlight trim at the same time.
Bumper guards add to the issues, lol.
The grill and grill trim are the most delicate parts. Flimsy, brittle, and very unforgiving - especially the grill tabs.
1972 GTSquire Wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2014 at 5:24PM
Scott, when I put the GTS back together:
Install radiator support leave bolts a bit loose.
Install liners on fenders:
Work on fender to door gaps.
Install hinges and hood after squaring up things:
Have shop dog inspect work:
stand back and go SEXY!!
Stare at pile of trim. And all the back up trim you have:
Don't forget new radiator support bushings:
Sit back again and enjoy staring at your car:
Well, that's my car. Off my koolaid!! lol
Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2014 at 5:30PM
i'd fire that shop/guard dog! that vette got stripped right under his nose Shocked
kychevyguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 02-April-2014 at 12:29AM
But man, what a shop the dog is guarding. Nice shop! (Nice car too!)
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 02-April-2014 at 11:22AM
Andy - thank you! Great pictures!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 30-April-2014 at 2:15PM
No problem man. Hey, you get the AC stuff squared away? Meant to give you a call to BS for a bit, but work and life has been kicking my butt
Andrew
Regul8r 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r 2 Quote  Post ReplyReply Direct Link To This Post Posted: 24-November-2016 at 6:19AM
and remember...
hang your door and adjust the gaps on the BACK EDGE.
The door gaps fit to the body of the car and THEN the front fenders adjust to get the front gap correct.
DO NOT move the doors to align with the front fenders.
This is why the core support has shims and there is so much play in the fender mounting.
Remove a shim or add a shim to get a good door gap top to bottom.
bdaugette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdaugette Quote  Post ReplyReply Direct Link To This Post Posted: 28-November-2016 at 9:58AM
Is the core support bushing the Chevy type?   Did you use them for your entire car?
Bill Daugette
72 GTS 351C 4V
This page was generated in 0.098 seconds.
